Old 02-24-2013, 05:23 PM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
Default RideTech Tru Turn
Yeah I know, it's probable been answered but I've been looking through posts for days and don't feel like I can wrap my mind around the entire thing.
My 69 Camaro should be delivered this Saturday and I would like to get started with the order process. I could just go to the many great reps here with Ridetech but I was hoping to get everyone's thoughts and impressions as well.
I'll most likely be going with True Forged 18x10s front and 18x12s rear.
#1. I like the Tru Turn system but want more than the suggested 2" drop up front. Prefer the tires tucked under the fenders and realize I may have to go with 9.5s. At the very least I'm wanting 3" of drop. Which leads me to the question. I'm centering the entire suspension around the Tru Turn as a system. I'll get the Tru Turn system (including tall spindles), muscle bar, and the Strong Arm UCAs/LCAs. Why couldn't I add the Chicane kit, or my own top hat, to allow the use of standard coil overs with spherical rod ends top and bottom. Then I could use a long coil over with the same suggested suspension travel and mount it deeper up top. I also realize the LCA may no longer be parallel with the ground (if it is at all) and would slightly alter the intended design, but with the improved design RideTech engineered into this system through the suspension travel would another inch of drop really alter it that much? I've even considered going as far as channeling the front subframe into the floor pan to give more drop. And air suspension isn't the route I want to go. These are still designed at a specific ride height.
#2. I want to go with the Kore3 14" C6 ZO6 brakes. It's my understanding that aftermarket systems designed to work on the factory GM disc brake spindle will work with the tall RideTech spindles. Do I have to get the Kore3 kit for tall GM spindles http://kore3.com/proddetail.php?prod=10104-03 or the short kit http://kore3.com/proddetail.php?prod=10103-03? Has anyone installed the Kore3 kit on the RideTech spindles? The reason I ask is I found a couple threads here and there where someone ran into issues installing aftermarket brakes on these spindles and the mounting bolts protruded beyond the spindle flat surface. The answer was to machine a nut down thinner to allow clearance to the rotor. Will I have the same issue with the Kore3 kit.....spindle surface to rotor surface clearance? If I have to go with the tall spindle which outer wheel bearing i.d.?
Many of you guys have been there and done that. Was hoping for some real world input.
I'll get a project journal started and document any improvements as I go for the next guy.
Thanks,
David
