Old 03-08-2005, 12:24 AM
rockdogz's Avatar
rockdogz rockdogz is offline
Default U-joint question
Is it bad that the u-bolt overlaps the cap on the u-joint by about 1/2? Normal or wrong u-joint?
-Tom
camarorestoration.com
Old 03-08-2005, 08:52 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Looks normal to me.
Old 03-12-2005, 10:41 AM
chicane's Avatar
chicane chicane is offline
Its normal on that type of yolk. The only thing you need to worry about is, that the u-joint cap fits the yolk and is the proper width in the yolk itself.
Old 05-19-2006, 07:10 AM
rockdogz's Avatar
I finally found out that the U-joint I had was too small. I had to have the end of my driveshaft replaced for the larger U-joint size to match the yoke.
-Tom
