Old 02-25-2013, 07:32 AM
69-nova 69-nova is offline
Default LT1 oil pressure problem HELP!!!!!
hey i need some help. recently i bought a 94 firebird with an lt1 to have as a daily while i build my 69 nova. the firebird has 82k miles and isnt stock was built about 6k miles ago. usually wen i start my car and its cold my oil pressure is around 60. then wen it warms up its at 35ish at idle and 40 cruising at 1k rpm.well yesterday i noticed it was at 40 wen i start the car up wen its cold and about 25 30 at idle and 35ish at 1k rpm. should i be worried? any help is appreciated.
Old 02-25-2013, 12:04 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
Oil level and condition ok? What mods if any? Also have u verified with mechanical gauge. 30 psi is plenty. Only required ~6psi per gm specs at idle.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 02-25-2013, 12:58 PM
Sounds fine. Couple things to check are is the gauge accurate? Have you by chance changed the oil viscosity or have the outside temperatures changed during this time? I honestly, wouldn't be worried but would look into the gauge working correctly etc just to be proactive about it all.
Old 02-26-2013, 05:32 PM
the oil level was a lil low so i added some. i did a oil change about 800miles ago with royal purple. yes its modded. different heads lifters pushrods rockers cam and throttlebody. im going to put another gauge in and check it. and i have heard that they can run off that low of oil pressure just thought it was weird it randomly decided to drop 10psi
