Old 03-02-2013, 10:41 PM
67XR7's Avatar
67XR7 67XR7 is offline
I personally went Dse , due to weight, ease of install, oem replacement parts and didn't have to pay extra for ford pattern. RS stuff is really nice and seriously considered it. The question you should be asking yourself is will the coyote fit in the RS setup with little to no extra mods? You know it will fit the Dse.
1970 Z28, Pm me if interested in wheel tool rental
Old 03-03-2013, 06:48 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Call both companies. Tell them what you are doing. See how they respond.
It's a lot of cash you are about to spend. A few minutes on the phone will probably sway you to one or the other.
Jeff-
Old 03-03-2013, 01:55 PM
214Chevy's Avatar
214Chevy 214Chevy is online now
My answer is, both being great products and as far as one being better than the other would be a matter of personal opinion. Unless someone has owned both chassis's for a die hard comparison, I don't thing you can go wrong choosing either. If RS saves you $1500 with no extra cost for the Coyote mounts, etc., buy the RS and use the $1500 elsewhere on your cars restoration process.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-03-2013, 02:29 PM
DOOM's Avatar
DOOM DOOM is offline
Two great products you really can't go wrong.
Mario
USCOLLISION
Old 03-21-2013, 06:31 AM
Tony@Roadster Tony@Roadster is offline
We can set up for the Coyote motor with no issues at all. Both the subframe system and the crossmember are designed with the same suspension geometry however I recommend you do a close inspection of your front sub rails. The Mustangs are prone to rot in that area. Our subframe system replaces the OE subrails all together and ties into the OE torque box location simplifying installation and reinforcing the front even further. If your OE rails are in good shape and you are only planning on some track and autocross abuse with alot of street miles, the front crossmember will suit you perfectly.
Here is complete Fast Track subframe system.
Here is the crossmember only with optional strut tower panels.
Old 07-10-2013, 01:41 AM
Dipped's Avatar
Dipped Dipped is offline
I'd go with Roadster simply because you are getting a system from a manufacture rather than a hype fueled brand.
1968 Firebird
lS3/T56/9"/24 Pistons/Forgeline VX1s/Faulty "Ride Height Too Low" Shocks
