Concept One just released a low mount A/C solution for the LS9 in 67-69 Camaro with a DSE sub. I look at the kit dimension and it may even work with a stock sub w/o notching the sub.
That modified vintage air setup looks nice, but I didnt see a power steering pump?
We did an LSA in a Speedtech subframe....had to cut it for the stock LSA AC compressor. The alternator just needed a minor notch. Keep in mind that the LS9 has a different blower intake/TB setup and if you try and use that accessory drive on the LSA you will run into a problem at the LSA throttle body
The AC looks to be the same or very similar bracket between the two (LSA/LS9) but you will want to swap out that for a Sanden anyways if you are not looking for headaches plumbing it.
Keep your eye on the Ridetech modifications....looks the cleanest so far!
