Old 03-06-2013, 04:09 PM
I am fairly certain that it is blue to spin the right way, but you can always de-pin the connector and swap em if its wrong. Use some test leads to a battery and check.
No problem helping, we are an AAW dealer and use this kit alot, along with the Dakota Digital so it was on the tip of my tonque.
Just ask if you are needing any help. Oh an make sure you don't mount the fan module under the hood, it can be ruined with moisture. Glove box side under the dash above the kick panel has lots of extra room for it, but you have to run the wires across. I just know the driver side is a bit tight above the kick panel. Good luck!
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 03-07-2013, 04:03 PM
468Camaro's Avatar
468Camaro 468Camaro is offline
Great info.and dont assume the fan is spinnin,the right way by puttin your hand at the frontof the fan..put a piece of paper in front and make sure the papee gets sucked up against the radiator...first ride with a Goodwrench Crate not cooling taught me that one...
Bowtie Nutt 68 Camaro Pro-Street 2x3 Ladder bar -backhalf 32x14 Dana 60 5.38, 406" 12-1. .Chet Herbert Billet Roller .645" 106' .Brodix Trk1, 830" Annular,Victor.glide-brake.. Needs Real windows.. 1989 Vette Z-51 357" 4bolt Forged, Dart IIS,Comp cam..Billet Specialties, 86" Iroc-z 468-400 ,2003 Roadstar 102" ..
Old 03-07-2013, 04:05 PM
468Camaro's Avatar
Great info.and dont assume the fan is spinnin,the right way by puttin your hand at the frontof the radiator...put a piece of paper in front and make sure the paper gets sucked up against the radiator...first ride with a Goodwrench Crate not cooling taught me that one...
