Old 02-28-2013, 10:34 PM
you should be good now that you clearanced the primary. You could put all the tricks in there but it take air flow to keep it from burning up.
Nice job on the carb. Sometime you have to thow the book out the window and go by gut feel and fact. Are you getting any idle circuit from the secondaries?
Old 03-01-2013, 06:00 AM
Sieg's Avatar
Sieg Sieg is offline
Awesome! I can be the only guy at Lat-g with a mini-brake duct routed to the #5 primary! I'm on it!
Thanks - I should have tossed the rules on the carb sooner, but fell victim to trusting the tech's specification. I did email him my experience and results so hopefully it benefits others.
I do have a reasonable signal from the secondaries, now that I've found the zone I'll be able to fine tune balance front to rear and optimize signal and vacuum. Then I can get into tuning and testing the fun stuff - pump cams and squirters.
Old 03-01-2013, 08:17 AM
intocarss's Avatar
Wouldn't that be called a "plug duct??
Glad you're making progress
Old 03-01-2013, 09:10 AM
Sieg's Avatar
Gotcha.
Plug Duct acquired, installation should be relatively simple.
Old 03-05-2013, 09:33 AM
Sieg's Avatar
Back to business..........
I fiddled with the fuel screws and throttle positions and obtained near 12" vacuum at 1K rpm which is as good as it gets with this cam IMO.
Throttle response right off idle felt good actuating it by hand. The initial timing was 13-14* with 21* mechanical. I decided to experiment with initial timing and see how the motor would respond. I bumped it to 15-16* and immediately had a big flat spot right off idle. WTF? Dropped it to 12-13* and still had the flat spot. Put it back to 13-14* and the flat spot was still there......I managed to create a flat spot without touching the carb settings, just changing the initial advance.
I list timing as 12-13*, 13-14*, 15-16* because that's what it is when locked down.
I've had subtle doubts since this motor went back together...........something hasn't seemed quite right and this latest issue is supporting my suspicions.
Gear drive or distributor possibly creating issues?
Old 03-05-2013, 06:09 PM
protour73 protour73 is offline
Dammit Sieg, hate to hear this!!! I am living vicariously through your ability to be able to be out working on your car. We are getting our butts kicked by winter this week here in Chicago.
Old 03-05-2013, 06:16 PM
Sieg's Avatar
I'm taking a little break from it........5 hours yesterday, 6 hours today, and probably 4 hours tomorrow...........pressure-washing concrete in the rain.
Old 03-05-2013, 06:23 PM
Probably best, or else you get wrenches stuck in the garage walls from the ole "Frustration Toss"!! LOL
Old 03-07-2013, 08:31 PM
glassman's Avatar
glassman glassman is offline
Man carbs can be a bi?€h. Makes me want to mow lawns for a month to get efi...
Old 03-07-2013, 08:38 PM
Did the engine temperature change? That amount of timing shouldn't make much difference to a bog. You aren't going to tune out a stumble with idle mixutre and transfer slot. It's time to start playing with accel pump cams.
