Old 03-07-2013, 10:40 PM
etp2563 etp2563 is offline
Default Centered 9 inch?
I have a 63 Galaxie that I built a fab9 rear end for and I built a custom 3 link suspension for it. My question is that I centered the driveshaft with the yoke and tunnel in my car and I know from a few other 9 inch rear ends is that the passenger tube is longer than the other. I made both sides equal lengths and now I have the same length axles in both. I have driven the car a few times around the block and I can't tell in major difference in driving it, it seems to drive just fine. I want to make it into a pro touring car and do some autocross in it. My biggest question is will having equal axle tubes make a big difference in handling or is it something that wouldn't be noticable or should i add a shim or cut the tube and add to the passenger side axle?
Old 03-08-2013, 09:33 AM
JasonElvisHeard JasonElvisHeard is offline
I'm a little confused by that you are saying,
You can either have a centered pinion or equal length axles, not both. If the pinion (drive shaft) is centered then you will have axles that are about 4 inches different in length (depends on the center traction device).
Either way,
There will not be a problem with either of those setups, typically you will never feel a difference from having centered pinion or equal length axles.
Jason
Old 03-08-2013, 11:21 AM
DRJDVM's '69's Avatar
I think what he is saying is that the motor is still offset... But the rear end yoke is now centered relative to the rear frame (since the axle tubes are now equal length rather than offset like the motor)
So you induce a slight driveline angle in the horizontal plane... Not just the vertical plane
A lot of guys have that set up when the swap out rear ends from other cars... From my understanding it usually doesn't cause an issue... I would think its influenced by how much of a difference in offset you have
Old 03-08-2013, 12:02 PM
If his axle tubes are equal length then the housing is centered but the pinion of offset to pass side. If the pinion is centered then the axle tubes would not be equal length. If the axle tubes are equal and pinion is centered the the driver side wheel is touching or outside the quarter!!
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 03-08-2013, 03:22 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
Exactly
Old 03-08-2013, 05:59 PM
well my driveshaft is centered and my axle tubes are too, it looks really straight and dead on and it actually tracks the front tires. sorry for the confusion though, i just wanted an opinion on this. I was gonna change some things on it, but if it doesn't present an issue when im going around the track then im fine with that.
Old 03-08-2013, 06:02 PM
Like I said everything looks true and fine, I was just wondering if I would run into any issues because it drove fine when I test drove the car. My driveshaft and pinion angle seem to be good too because there was also no vibration either.
Old 03-08-2013, 06:20 PM
FETorino's Avatar
FETorino FETorino is offline
A few pictures wouldn't hurt.
GW loves my photos
What's centered in this photo?
Rob in SoCal
Old 03-08-2013, 07:20 PM
I dont have any clear ones of exactly what I am trying to explain, Im in afghanistan right now, so when i get home ill definitely get more detailed photos. I found one that probably shows ore of what I am talking about. It isnt the finish project, I am probably going to change a few things and reinforce it a lot because the 390 I built has a little over 500 ft. lbs of torque so, its going to need it. I am perfectionist with these things and I change them when I am satisfied and felt that it is where it needs to be
