Old 03-08-2013, 05:08 PM
67rstbkt 67rstbkt is offline
Default Leaf spring perches for a ford 9
On the ford 9 I have for my firebird, it looks to me like the axle tubes are larger compared to the 10 bolt. Will the stock GM replacement perches fit? Is there a different set or size I should be looking at? Thanks
*Edit* I measured and they are slightly larger at 3.25 while the GM perch is made for a 3"
So what are you guys using? Is there a 3.25 version that I'm missing or should I be picking up one of those universal ones in that size? I'll be using this for the lower links on my Ridetech setup.
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
Old 03-09-2013, 11:12 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Most everything I know is 3" perch. Found these guys adn it looks like they can make or have what you need.
http://www.ballisticfabrication.com/...ch_p_1485.html
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 03-11-2013, 07:51 AM
Thanks, I took a chance and bought the replacement GM multi leaf mounts (Moser) at Summit and they do fit almost perfectly. A touch on the upper edges with a die grinder (and I mean just barely) and they will be a perfect fit.
