Old 03-15-2013, 10:48 AM
rickpaw rickpaw is offline
Here's my 67 Firebird. I tackled everything (sheet metal work, body work, final assembly). The only things that were sent out were final paint and engine machining.
Prior to this, I have not done any welding or bodywork. Kind of dove in head first.
Tu
Old 03-15-2013, 11:29 AM
RussMurco's Avatar
RussMurco RussMurco is offline
Tu
And a damn fine job you did... Looks great!!!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 03-24-2013, 10:40 AM
66138 66138 is offline
cudo's on a great job and tackling this yourself ! Many hours of learning when you do that but you get that satisfaction !!
66 SS396--502 SS700
https://picasaweb.google.com/1036140...k:headscratch:
Old 03-25-2013, 09:47 AM
garyb garyb is offline
Question
Maybe a dumb question, but on your picture that shows the 'new' quarter screwed in place for tack/welding, I noticed the screws are on what's left of the existing quarter. Are the two overlapped as in lap welded? I've always wondered. I know when I did my trunk pan, I overlapped, used metal screws to hold in place and used an air body saw to cut through the old and tack as I went along.
Gary
The project my son and I've been slowly working.
'71 Cutlass Supreme
Old 03-25-2013, 09:58 AM
The two were overlapped, but I cut the overlapped pieces and butt welded them together as I went along. I used a black marker to draw up the cut lines. You can see it in the picture. Afterwards I went back and welded up the screw holes.
Tu
Old 03-27-2013, 06:57 AM
Anchor's Avatar
Anchor Anchor is offline
Mine was an outside build.... Only just got moved into the garage.
67 SS. AES398. 2x T-netics mid frame 72's. TCI PT F&R clips. T56. Recaros. Digital stuff. etc etc etc.
* 67 SS Nova Coupe * AES LS & T56 * Twin Turbonetics 72mm Mid Frames * TCI Pro Touring Front & 3-link Rear *
Cuttin up original metal, cause I can....
Old 03-27-2013, 06:59 PM
TorqDork's Avatar
TorqDork TorqDork is offline
Thought I'd add this here!
Completely home built start to finish
Video of build
https://www.youtube.com/watch?v=oBMM0u5eCqg&fmt=18
Engine Video
https://www.youtube.com/watch?v=h3f0xRlEI6g&fmt=18
SPONSORS: Edelbrock, Holley, PPG Bilstein, Classic Industries, Heidts, Eaton Detroit Spring, Energy Suspension, Stainless Steel Brakes, Phoenix Graphix, Classic Tube, Legendary Auto Interiors, Pertronix, Patriot Exhaust
The Following User Says Thank You to TorqDork For This Useful Post:
Chiva (12-03-2018)
  #548
Old 03-27-2013, 09:26 PM
^^^^^^^^^^^^ very impressive!!! Way to go!
Old 03-28-2013, 04:43 PM
camaroinct's Avatar
camaroinct camaroinct is offline
Wow, Very nice complete build on the red firebird
Old 03-30-2013, 09:24 PM
G-Body's Avatar
G-Body G-Body is offline
Final blocking next getting there.......
