Old 04-28-2013, 11:53 AM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Here is the Original glass according to http://www.camaros.org/glass.shtml
Background
The primary first-generation Camaro glass supplier to the Camaro assembly plants (both now closed) in Norwood, Ohio and Van Nuys, California was Libbey Owens Ford (LOF). LOF continues to do business as a division of Pilkington and has reissued their old glasses under the name Pilkington Classics. A tertiary supplier of first-generation Camaro glass was Pittsburgh Plate Glass (PPG), which also supplied equivalent glass to the Firebird assembly plant in Lordstown, Ohio. Contractual agreements theoretically allowed GM to purchase from either supplier for either GM division in the event of a shortage at the other supplier, but the only PPG glass use that CRG has verified to date in 1967-68 Camaro is occasional use in 1967 vent window glass. While there seems to have been some increase in the amount of PPG glass in '69 Camaros, especially at the Norwood Camaro assembly plant, due to the dominance of LOF glass in Camaro, this edition focuses on LOF glass. PPG marking details remain less well known to CRG, but as of the 27-Feb-2006 release are now briefly covered in the PPG marking appendix.
__________________________________________________ __________________________________________________ __________________________________________________ ______________________________________
Mike's Muscle Rodz supplier is located in Ontario, California. JRD international. http://www.classic-new.com/
The company doesn't say they make glass at all. So, I did a little research on it. Well, when a company has a warehouse in California, then it is most likely getting parts for overseas. Here is the bill of ladiing information from google.
Perhaps the link is much easier to read from Google translate.
http://translate.google.com/translat...lr:lang_1zh-CN
Bill of lading information in North America Date of arrival 2011-01-17 Bill of lading number OERT101701A00016
Importers and exporters
Name of the importer JR DISTRIBUTOR INTERNATIONAL INC., Names of the exporters YUAN CHANG GLASS CO., LTD. Importers address 1229 W. STATE ST, ONTARIO, CA Exporters Address NO.100, LANE 800, CHUNG SHAN SOUTH 91762. USA RD., YANG MEI TOWN, TAOYUAN HSIEN,
TAIWAN, ROC
Name JR DISTRIBUTOR INTERNATIONAL INC., Address 1229 W. STATE ST, ONTARIO, CA 91762. USA
Product Information
Weight (kg) 19234.00 KG Size 56.00 CM Number 54.00 WDC Container volume 0.00 Shipping Information
Carrier
Country of origin China (Taiwan) Referred to by the carrier OERT The clearance zone
Name of the vessel OOCL NINGBO Arrived in Hong Kong Long Beach, California Voyage 63E52 FOB port Kao Hsiung, Kaohsiung Route Taoyuan, Taiwan Destination
HS Code
Office of departure
Appraisal 0.0 Mode of transport 10 Descriptions
Product Code
Product Description OOLU7759803: WINDSHIELD (LAMINATED) AND SIDE DOOR GLASS AS, SORTED Marks OOLU7759803: JR LOS ANGELES JR-1152B C / NO. :1-54 MADE IN TA, IWAN ROC
The company that makes the glass for JRD International is located in Taiwan.
Yuan Chang Glass Co. Ltd.
No.100, lane 800, chung shan s. rd.
326 Yangmei, Taoyuan Shine
Taiwan
Phone:011-886-3-4755151
Fax:011-886-3-4751729
http://yc-glass.myweb.hinet.net/index.htm
Fit? Vendors typically tell you that they have zero issues with fit, but the problem can occur after you have the glass installed. For example, a friend of mine has a 1969 Camaro Z28 and it need new back glass. So he used Auto City Classics glass, it fit the car great. The glass cracked within 6 months. The car was never driven at all, just sitting in the garage. He installed PPG glass installed in it, but it was bought from a closing PPG warehouse. There has been zero problems with fit and the glass has never cracked. Same glasser installer.
Oh AutoCity Classics uses a manufacturer out of Thailand now, but they have used several vendors from China.
Original Poster asked me a question on where to buy the glass. Well, I go to the supplier. Pilkington Classics
http://www.pilkington.com/north-amer...s/default1.htm
1-800-848-1351
Jeff
