Old 05-03-2013, 07:34 AM
Payton King's Avatar
Default Oil Pan
Here is the oil pan that I picked up from Hendrick. Left over Busch Grand National pan that was never used with piston squirters.
90 degree fitting on the front of the pan is for the piston squirters
Old 05-03-2013, 07:54 AM
Default Piston squirters and pan interior
Old 05-03-2013, 08:04 AM
Now if that's not Pro Touring -- I don't know what else is! HAHAHAHAHA
Old 05-03-2013, 08:05 AM
Ron in SoCal's Avatar
^ I want one. Garage art
Ron in SoCal
69 Camaro in progress
Old 05-03-2013, 08:29 AM
fleet's Avatar
fleet fleet is offline
Wowł!!!
Like the old saying goes... "If it's good enough for pro-touring, it's good enough for NASCAR."
Old 05-03-2013, 08:38 AM
Default The "pro" part of pro touring
may apply, not sure about the touring though...
That pan probably weighs about 25 lbs. They make them thick so they do not get sucked in by pump. When those pans were new and they were running SB2 motors they were about $2100. I got it for $450 with fittings, instruction sheet, gaskets.
I hear you on the garage art. I have almost bought used parts that I would never use just for that very thing.
Old 05-03-2013, 09:04 AM
GrabberGT's Avatar
Is there any concern about the pick-ups being all on the same side or does the dry-sump nullify that issue. I take it you plan to turn in more than 1 direction.
Chris
Its not a Vega!!!!
Old 05-03-2013, 09:05 AM
coolwelder62's Avatar
That's cool.Fill it full of ranch dressing for dip bowl.
Old 05-03-2013, 09:43 AM
Default Rotation
of the crank throws oil to that side of the pan...why the pick ups are on the right. Have a 5 gallon tank that will have about 3.5 gallons of oil in it. Motor gets oil supply from tank not from pan, so it will not starve in right hand corners....I asked the same question when I bought it.
Old 05-03-2013, 11:15 AM
GrabberGT's Avatar
Thanks. Theres always something new to learn.
Chris
Its not a Vega!!!!
