Old 05-01-2013, 06:11 AM
DOOM's Avatar
DOOM DOOM is offline
Default TT big block pros and cons lets here it!
Well guys it looks like the TT engine is going to happen. So lets here the pros and cons.
Mario
USCOLLISION
Old 05-01-2013, 06:28 AM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Pro: power and plenty of it
Con: weight, heat soak, cost, packaging.
Greg
Old 05-01-2013, 06:32 AM
Ketzer's Avatar
Ketzer Ketzer is offline
If it is what you want and you are this excited about it... there are no cons.
Jeff-
Old 05-01-2013, 07:16 AM
Pros: It's what you want, aesthetics, power.
Cons: Weigh more than a sherman tank, nearly impossible to cool in some circumstances, handling, modulation for traction control, maintenance, reliability, packaging, cost.
Old 05-02-2013, 05:59 PM
64duece 64duece is offline
I've done quite a few...there are never a lack of smiles!
The weight isn't the best option for a true corner carver. Large cube LSx would be more ideal if this is a concern. It'll still handle with the right springs and sway bar...just be a a few % heavier on the nose.
If you have e85 available, you can run without an air to air intercooler which will be your biggest concern to cool the car. Next option would be pump gas/water meth setup. Either will make much more power than the street can handle. If you feel an air to air is required, the air ducting and fans play a crucial role in cooling the car with a large restriction up front.
I have a 572" BBC w/ twin PT76GTS in my 55 Chevy. It'll run 150mph on 15lbs of boost (e85/watermeth) in the 1/4 mile. It's a beast at 4000+lbs but the 4L80e and extras really play a large part aswell. Scares the crap outta anyone that rides beside me!
Dennis
Moore Racecraft
The Following User Says Thank You to 64duece For This Useful Post:
fleet (04-22-2020)
Old 05-02-2013, 06:06 PM
fleet's Avatar
fleet fleet is online now
Mario,
As a friend of mine used to say...
"Temporary inconvenience for permanent (in this case Perm-a-grin) improvement."
BTW-are you going to use an aluminum block?
Old 05-02-2013, 08:13 PM
DOOM's Avatar
Thanx Dennis ! I will bring this up to Steve.
Originally Posted by compos mentis View Post
Mario,
No aluminum block Skip . Steve wants to use my 572 .
Mario
USCOLLISION
Old 05-02-2013, 09:33 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Well, I got to hear this twin turbo LSX engine run in Brian Thomson's Street legal 96 Impala. With over 2,000 on tap. I am not sure why people want a big block.
http://www.superchevy.com/technical/...e/viewall.html
Jeff
Old 05-03-2013, 01:56 PM
gnx7's Avatar
gnx7 gnx7 is offline
My buddy made 950rwhp with a stock LS3 block, $100 LS crankshaft, $600 compstar rods, and off the shelf Diamond pistons. He runs budget $1400 SDPC ported LS3 heads and stock LS3 intake. $400 cam, $500 morel lifters, stock rocker arms. He runs a GTS76 single turbo and $400 Treadstone intercooler. e85 fuel
Engine weight is around 425lbs without turbo.
You will save hundreds of pounds off the front end with LS power. His engine revs to 7800rpm when needed. 7K normally
He runs a $1100 Mcleod RXT twin disc clutch that has the pedal pressure of a Honda.
No need for TTBigBlock unless its a drag car. You can into plenty of trouble or out of it... running a turbo LS setup.
A stock 6.0 LS shortblock, stock ls3 heads/intake, medium size cam, single s480 turbo recently went 8.65@157mph in a Mustang running a TH400. Imagine what a built up one can do.
I'm hoping to run some 9's with my '69 Chevelle project and if not... I'll put on a bigger turbo.
Old 05-03-2013, 02:33 PM
NOPANTS68 NOPANTS68 is offline
Pros- it's not an LS
Cons- it's not an LS
It's def the package I'd go for given that budget. Sure the LS is lighter, smaller, better tech, and apparently made by god- but who cares. Build what you want. If you set the car up right, nothing will catch it from a roll anyway. Hard to argue your car handles better when a guy just put 10 bus lengths on you. lmao
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
