Closed Thread
Old 03-10-2013, 05:21 PM
meanchicken meanchicken is offline
Default 68 Camaro
Located in Orange County, CA
First $23,000 takes it.
My 68 which has the following major upgrades:
* ZZ502 with an Edelbrock RPM Air Gap intake and Edelbrock Performer 825cfm carb, Holley blue electric fuel pump (makes about 550HP and 575TQ)
* TKO-600 5 speed, 12" McLeod clutch, McLeod scatter shield, Centerforce flywheel
* Global west tubular upper and lower control arms with del alum bushings, Hotchkiss sway bar, fast ratio steering box and power steering
* Moser 12 bolt rear end with Detroit True Trak limited slip, 33 spline axels with tapered ends and pressed on bearings, Ford 9" housing ends
* 3 leaf rear springs with Poly bushings
* SSBC 4 wheel power disc brakes
* Be Cool aluminum radiator
* Flaming River stainless steel steering column with tilt and a Grant Boomerang steering wheel
* Covan Classics Dash insert with all electric gauges (Speedo, Tach, Fuel, Oil, Temp, Amps)
* Solid body mounts
* All new M&H wiring harnesses installed
* Painless Performance Extra 11 circuit fuse block
* Lots of other stuff and extra parts.
* Fiberglass hood with a 96/97 SS Camaro scoop
* About $25,000US in parts alone installed...I have all the receipts
* Approx. 6000 miles on the build
* 5 spoke 17" wheels with new Kuhmo tires installed all around about 200 miles ago
It will need minor body work to repair rust in some of the usual places (behind left rear wheel well, and minor below rear window on driver side), and a few minor dents and dings, but over all it's straight and clean, perfectly aligned and tracks perfectly straight...never been in a major accident.
I've seen 68 Camaro rollers in similar or worse shape go for $8K US and as mentioned before, I have about $25K of parts installed.
It runs strong and pulls like a freight train. I've never had it to the track but it has outrun a C6 Z06 Vette all the way up to about 140mph. Based on the feel compared to my 87 Grand National, I'd guess it will run in the mid to low 11's in the 1/4 mile as is...as long as it's launched well.
In the corners it handles very well. I kept pretty close to a BMW M3 on a local canyon road...he'd pull me a little in the turns and I'd get it back between the turns. The M3 driver was blown away at the other end. ;-)
Here is a photobucket album to show more of the car and what has gone into it. http://s1334.photobucket.com/user/OC-Dotcom/slideshow/
If you go to my youtube page meanchicken87 there are a couple brief clips with the Camaro there.
Attached are a few pix. More available via e-mail [email protected]
Some action video's.
https://www.youtube.com/watch?v=9g87drlsbQg
https://www.youtube.com/watch?v=c1GK1jkrwfQ
https://www.youtube.com/watch?v=Pi7TFWHeNF0
First time I started up the ZZ502...
https://www.youtube.com/watch?v=FJkNsOckHhw
Thanks!
Tim
87 Grand National:Czarnota stroker roller V6;ported heads/intake;3200 billet stall 10";built 200R4;PTE 6265 DBB;3" THDP;TT Alky chip;60# inj;HD Adj WG actuator;AFPR;160* stat;Alkycontrol;TRC Big Mouth;PTE FMIC;Hooker cat back...and a boost gauge. 11.14@122 on 24lbs
4-sale 68 SS Camaro:ZZ502;TKO-600;Moser 12-bolt;Global West control arms;QA1 coil overs;SSBC power disks;quick ratio steering;Hotchkis sway bar;solid body mounts;Be Cool rad;Pertronix ign;other stuff. 4-sale
Old 03-10-2013, 09:08 PM
Going to need a price please.
Old 03-29-2013, 07:20 PM
Got it!
Sorry for not being here in awhile...starting a small business is time consuming.
Price...I'm looking for $23K
More pix are at this link.
http://www.turbobuick.com/forums/thr...camaro.392218/
Old 04-06-2013, 09:56 PM
To the top.
Old 04-17-2013, 05:07 PM
Questions, concerns, feedback?
I've had some interest, but the car is still available for sale.
Price mentioned above is negotiable.
Old 05-07-2013, 11:42 AM
Old 05-13-2013, 12:38 AM
Old 05-13-2013, 09:51 PM
Got one possible buyer offering cash, and the Aussie is in town.
If you have interest in this Camaro, don't wait much longer. It will be gone soon.
Old 05-24-2013, 10:55 PM
Car us still available.
One offer fell through (guy got beat by his wife)
and a second offer for $23K is pending actual cash in hand. I'm not waiting...car will go to the best offer and first to place cash in hand, so if you are interested, call me at 949-888-5999 and lets do this.
Old 05-31-2013, 10:24 PM
Howdy,
$23K
Thanks!
Tim
Closed Thread
