Old 06-10-2013, 06:36 PM
protour73 protour73 is offline
Now on a side note: I received an email from a gentlemen and he warned me that the Moser ends are designed for only straight line use and could fail. Anyone have any thoughts on this ????
Mind you this car is actually being build to be driven with very limited auto-cross.
This quite disturbing as I included the c-clip eliminators to my Moser rear end when I ordered it directly from Moser and told them the car was primarily for street use but occasional track use. The guy NEVER said no, this won't work for you!!
From Moser website in the FAQ section:
Can I use c-clip eliminators for street use?
Answer - We do NOT recommend using C-Clip Eliminators for street use; a C-Clip Eliminator is made for drag race only ( As a safety issue so you do not loose an axle, if it breaks ).C-Clip Eliminators are made for the straight shot down the strip. If you use C-Clip Eliminators on the street the aluminum block will eventually flex from cornering or just going around curves causing the C-Clip Eliminator to leak Rearend fluid.
Old 06-10-2013, 07:30 PM
Rick D's Avatar
Rick D Rick D is offline
Scott I think if I remember correctly don't you have the Ford Big bearing ends on your housing?? If so then you shouldn't have any issues?
Rick
Old 06-10-2013, 08:28 PM
Yes I do
(sorry for the hijack Marty!! LOL)
Old 06-10-2013, 11:46 PM
glassman's Avatar
glassman glassman is offline
I was told the same thing by the tech who did my 12 bolt, he said do a "nine inch", 3k or rebuild my 12 bolt for 900, i am warned about pad knock....we'll see...
So are the Strange Eng ones any different? i couldnt quite follow what was meant a few posts back...me need to research more...
Any more progress pics Marty?
Is it going to SEMA? if so where?
U got any trails in mind if you go for a weekend trail juant....?
Old 06-11-2013, 09:48 AM
syborg tt's Avatar
I will be calling Moser this afternoon to get confirmation.
Yep, Plenty I am going to try to get a couple more out today
Yes and I have two booths that I would love to be in but only time will tell
last year bunch of guys told me about a pretty cool trail network near the Optima Challenge but I can't remember the name.
marty-mj
Old 06-11-2013, 12:27 PM
cencalc6 cencalc6 is offline
Now that the body work is complete Kenny applied the Line-X protective coating to the underside of the car because I plan to keep and
drive this car.
I plan on doing the same, looking good Marty
Old 06-11-2013, 04:29 PM
kennyd's Avatar
kennyd kennyd is offline
Trey was kind enough to PM me what he's learned so I thought I would share it with everyone.
here is the info and thank you Trey
STRANGE C-CLIP ELIMINATOR FOR STREET APPLICATION
http://www.competitionplus.com/drag-...t-application-
Strange Engineering, Morton Grove Illinois, introduces a new style, specifically designed for street and/or strip, c-clip eliminator for most 10 & 12-bolt GM car rear ends equipped with c-clip style axles. In the past, c-clip eliminators for these applications have been designed for drag racing, which use ball bearings. Ball bearing c-clip kits are fine for drag racing, but are prone to leaking and premature failure when used for prolonged street use. Our specially designed c-clip eliminator kit (A1033) utilizes Timken unit (tapered) bearings, which survive severe side loads and constant use.
The Strange A1033 also features two seals per axle shaft, ensuring a completely sealed axle end. Complete axle and c-clip eliminator packages are also available.
none of this bothers me , he never drives anything !
Old 06-17-2013, 09:58 PM
syborg tt's Avatar
Default 2nd Chance Camaro - Custom Works CF Front Bumbers
2013 06-17 2nd Chance Camaro - Custom Works CF Front Bumbers
www.2ndchancecamaro.com
Good Evening,
I really don't need to say much as they speak for themselves.
Pictures hosted by www.garagescene.net
marty-mj
Old 06-17-2013, 10:09 PM
Rick D's Avatar
Um me likey! So where did you get those??
Rick
Old 06-17-2013, 10:23 PM
syborg tt's Avatar
http://www.customworksproducts.com/
marty-mj
