Old 06-20-2013, 08:49 PM
atomicjoe23 atomicjoe23 is offline
I agree. . .I checked prices and the best I could find was from Speedway Motors. . .it wasn't terrible.
Plus the fact that I've got 14" front wheels means I'm stuck with OEM sized stuff at the moment. . .bigger wheels and tires are a GIGANTIC expenditure which I just can't afford at the moment.
'67 Pontiac Firebird 400 RA coupe
http://www.pro-touring.com/forum/showthread.php?t=26557
'97 Chevy Camaro 3.8/M5 coupe
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
Old 06-21-2013, 08:33 AM
T_Raven's Avatar
T_Raven T_Raven is offline
Originally Posted by Apogee View Post
All of the disc brakes from the '67-72 A-body, 67-69 F-body and 68-74 X-body applications will interchange so long as you get the spindles with the brakes. Not a lot of these in auto salvage yards in my area anyway, but lots of guys looking to offload their old parts after upgrading to performance aftermarket stuff per the post above. Check the classifieds, post wanted ads, etc and you should be good to go before you know it.
Tobin
KORE3
I know you know brakes, but do A body spindles work on a F body? I've always thought I've read they either don't fit, or will bolt on but aren't ideal.
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 06-21-2013, 08:51 AM
Apogee Apogee is offline
Originally Posted by T_Raven View Post
I know you know brakes, but do A body spindles work on a F body? I've always thought I've read they either don't fit, or will bolt aren't ideal.
They're the same exact spindles, just with different steering arms. There are several variations with respect to drum versus disc, steering arm bolt size (7/16 or 1/2), upper mounting boss thread size (1/2-20 or 5/8-18), etc, however they're all interchangeable within the A/F/X-body applications. Since the OP was asking about disc brakes, I wasn't including the drum spindles, however if you were to run aftermarket disc brakes, then that potentially opens those up as options as well depending on the manufacturer and/or kits.
Just as a side note, the '67 and older Nova/Chevy II spindles also look very similar to the A/F/X-body spindles, but have a different steering axis inclination, so they're not the same nor interchangeable.
Tobin
KORE3
www.kore3.com
