Old 06-20-2013, 09:11 AM
vette66 vette66 is offline
Default Electric Emergency brakes
Is anyone using the electric emercency brake kits that are out there? I see they have one that uses the principal of a lineloc. Anyone use that one?
Old 06-20-2013, 10:29 AM
RussMurco's Avatar
RussMurco RussMurco is offline
I've seen the one that has a large rectangle you need to install, it also needed you to hold the button as it pulled the e-brake and with that I though it was too large, heavy, and impractical...
http://www.estopp.com/#!about/c1x9v
I would like to see a line-loc version you found, sounds much more practical and I'd love to eliminate the e-brake handle/pedal for a cleaner look! It would only be a parking brake instead of an e-brake but I'm ok with that!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 06-20-2013, 10:30 AM
RussMurco's Avatar
And... Welcome to the forums!
Russ "Murco" Murray
Old 06-20-2013, 11:30 AM
Streetrod headquarters carries them. Looks to be a simple as putting in a lineloc. Thanks for the welcome
Old 06-20-2013, 12:04 PM
camcojb camcojb is online now
Originally Posted by vette66 View Post
Is anyone using the electric emercency brake kits that are out there? I see that have one that uses the principal of a lineloc. Anyone use that one?
I used a line loc style years ago, no electrical involved. It installed in the rear brake line; you pushed the brake pedal down, pulled up a knob and released the brakes. It held the pressure in the line, worked fine. Plus you can hide where the knob is to act like a theft deterrent.
Old 06-22-2013, 03:27 PM
Cam, do you happen to know what brand it was?
Old 06-22-2013, 08:30 PM
That's interesting, Jody. I'd like to know more as well if you have any info. They say that if it can't be driven away, it's less likely to be stolen. That even includes the high end thieves.
Old 06-22-2013, 09:50 PM
NorCal72's Avatar
NorCal72 NorCal72 is offline
https://www.streetrodhq.com/detail/3...ng_Brake_.html
I think I might be going this route as well. Interesting anti theft device as well, if you place the toggle in a hidden position.
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 06-23-2013, 06:50 AM
randy randy is offline
what about that constant pressure putting extra strain on the brake system? Imagine blowing up a expensive caliper
Old 06-23-2013, 06:53 AM
NorCal72's Avatar
Good point.......
