Closed Thread
Old 06-30-2013, 06:48 PM
b757jetdr's Avatar
b757jetdr b757jetdr is offline
Cable ties would be the easy route that I know of. An Aircraft crimping tool Is my guess. I wonder what you are coming up with?
So I knocked out one of the rears. I think I'm going to grab a set of 6" pliers in both lefty and righty. It would make this process way faster. Between my sausage fingers and the old 9" safety wire pliers I have this rotor took me too long.
[/QUOTE]
Rob,
Pretty good guess and description. I have the 6" left and right pliers if you need them? I will dig up that tool tomorrow and see about some pics.
Chris K
Aircraft Mechanics: So pilots can have heros too!
  #1102
Old 06-30-2013, 07:04 PM
FETorino's Avatar
FETorino FETorino is offline
So before I got around to safety wiring the rotors I had to build them up. It is a simple exercise but it took a bit of time to do. Part of this is me being anal about putting them together.
Why worry about assembling brake parts right.
I'll run through this quick. It also gives me a chance to show off my Wilwood floating hats.
Here one is.
It's AL like most of the front hats but you'll notice the T slots in it instead of just threaded holes.
Into these you inset these little T nuts.
Man that is a crappy picture. I can't wait to hear GWs comment on that one.
This allows the rotor to "float" on the hat. This really separates the hat and the rotor into two separate pieces. Having two separate sections of the rotor and hat helps to keep heat generated in the rotor off of the hat. By keeping the hat cool you are less likely to have any flex, giving you more feel and braking predictability under extreme braking conditions. A floating rotor also allows for much more contact surface between the rotor and brake pads since the rotor itself follows the path of the pads correcting any imperfection either may have as it floats.
Now with anything that requires a definitive torque value I make sure the threads are clean and free of burrs. In most cases that means a quick run of a tap through the threads.
In this case the stainless bolts are nice and hard compared to the T nuts so I just dry fitted them. If any of the bolts had bound as I was assembling the rotors I would have got a tap out for that one.
With these T nuts you use a small T wire to ensure the nuts don't rotate as you torque the bolts.
I didn't have any issues with this set. Once the rotors are completely assembled to hand tight it's time to loctite and torque them.
I use two sockets of the same size to make the next step easy. Once I torque a bolt I leave the socket on it and then go to the bolt directly across to torque in a criss cross pattern. the first socket serves as a marker to remind me where I just was.
Once you put a bit of loctite RED on all the bolts bolt and torque them to 125 in lbs (in this case) it's time to get out the safety wire pliers.
Rob in SoCal
  #1103
Old 06-30-2013, 07:10 PM
Sieg's Avatar
Sieg Sieg is offline
If you really wanted to show them off you should have taken FIRST SET of pictures IN @*^#$ FOCUS!
The second set get's you a big pat on the back.........you're actually making an effort! Women like that in a man.
Man those are crappy pictures. I can't wait to hear GWs comment on that one.
Why are you worried about GW?
  #1104
Old 07-01-2013, 12:18 AM
FETorino's Avatar
Originally Posted by b757jetdr View Post
Rob,
Maybe one of these
I figured he'd beat you to complaining about the photo quality. But you were first.
Rob in SoCal
  #1105
Old 07-01-2013, 06:18 AM
Nice parts -- nice write up -- I see that Cheryl took some of the photos and you did a couple of the others?
  #1106
Old 07-01-2013, 06:28 AM
Sieg's Avatar
I've never seen that safety cable system, very cool and quick!
  #1107
Old 07-01-2013, 07:24 AM
b757jetdr's Avatar
Rob,
That is the gem! We use it when access is limited. I will try and round mine up here at work and if your interested in trying it let me know.
Chris K
  #1108
Old 07-01-2013, 01:55 PM
intocarss's Avatar
How do we all know that..... with all your you just don't have a professional photographer on your payroll. Has anyone here ever seen a pic of GW with a camera in his hand??
  #1109
Old 07-01-2013, 02:34 PM
Sieg's Avatar
Old 07-01-2013, 04:14 PM
Just when we need a GRAINY picture.....
Closed Thread
