Old 07-01-2013, 12:11 AM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Default Best 5 speed manual
Hi Guy's,
I have a Friend that is looking to put a 5 speed in his Camaro, whats the best 5 speed, I told him to run a T56 Magnum, but he only wants a 5 speed.
Greg
Old 07-01-2013, 08:50 AM
Lowfast's Avatar
Lowfast Lowfast is offline
What kind of power/RPM will he be running? Street or Track? Need more info to determine the "best" 5-speed for his situation.
1965 Ford Falcon Hardtop - PT Build
TCI Supension | Team III Wheels | Ford 3v 4.6 & TR3650
Old 07-01-2013, 09:24 AM
Sieg's Avatar
Sieg Sieg is offline
His next tranny will be a T56 Mag.
A modified close ratio TKO 500 or 600 might be a consideration.
I've heard good reports about this company's boxes: http://www.libertysgears.com/ttc2.htm
Old 07-01-2013, 12:36 PM
Before a proper recommendation can be made, we must know what he wants to use it for?
Is there a 350 hp 350 sbc behind it?
Or is it a 7000 rpm LS stroker?
Will he track it? Or just cruise it?
Old 07-01-2013, 04:13 PM
Thanks guys,
It will be mainly a cruiser, with occasional track time and 450hp small block.
Old 07-01-2013, 04:22 PM
Originally Posted by Greg from Aus View Post
Thanks guys,
In that case a TKO 600 would probably be fine, but if more power, rpm and track use is in the cards.... the Magnum could be justified.
Old 07-01-2013, 08:39 PM
Anything but a tko.....Unless he likes a trans that shifts like a John Deere combine.
Old 07-01-2013, 09:47 PM
Hey just because you couldn't figure it out and decided to sell the car because of it.
Old 07-01-2013, 10:09 PM
I learn with time to exceed the intended application.
Old 07-02-2013, 12:06 AM
intocarss's Avatar
Put a Jerico in it and be done with it Yeah yeah they're loud.. It's a hot rod ain't it
