Old 07-02-2013, 01:34 PM
clill's Avatar
clill clill is offline
So is the long block LS9 ?
Old 07-03-2013, 08:54 AM
Semel1's Avatar
Semel1 Semel1 is offline
That is correct.
Old 07-03-2013, 09:07 AM
Semel1's Avatar
Default SMC Performance built 700HP LS9
Complete supercharger to oil pan (true LS9) with Edelbrock E-Force (Eaton 2300 TVS Supercharger).
Upgrade: Clevite race series main and rod bearings, 10% Over-Drive Powerbond, SFI approved crank damper, AN adapter plate and fittings for oil sump to tank lines, 65 LB/Hr Bosch Injectors, C6 Corvette Front drive accessories (alternator, PS pump, bracket, tensioner, idler and fasteners), GM high Torque starter, SMC Performance custom stand alone engine controls (harness, programmed ECU with final dyno tune, GMPP MAF element, 2-02 sensors, fly by wire pedal assembly), inter cooler, heat exchanger, coolant pump, surge tank and associated hoses and hardware.test run and base line tune before Shaun shipped it.
I will be using Dewitt's LS radiator and dual fans with oil cooler in side tank
Old 07-03-2013, 09:49 AM
Ron in SoCal's Avatar
Programming from Ecuador. Typo right? I'd love to laugh, but I might actually learn something here.
I love autocorrect too
Great project BTW
Ron in SoCal
69 Camaro in progress
Old 07-03-2013, 11:08 AM
Semel1's Avatar
Great project BTW
Love that autocorrect!!! Thanks
Dave
Old 07-03-2013, 08:35 PM
Semel1's Avatar
Default pictures as we started
Over to Mikes Home garage for the start
Name:  dave 63 001.jpg
Name:  dave 63 003.jpg
Name:  dave 63 004.jpg
Name:  dave 63 005.jpg
Name:  dave 63 017.jpg
taking off the trim
Name:  dave 63 019.jpg
rear trim and windows taken out
Name:  dave 63 020.jpg
previous work by someone
Name:  dave 63 021.jpg
Name:  dave 63 022.jpg
Name:  dave 63 023.jpg
Old 07-03-2013, 08:40 PM
Semel1's Avatar
Default more pictures as we get into it
checking all the door gaps etc
Name:  dave 63 024.jpg
Name:  dave 63 025.jpg
Name:  dave 63 026.jpg
Name:  dave 63 027.jpg
Name:  dave 63 028.jpg
Name:  dave 63 029.jpg
Name:  dave 63 030.jpg
Name:  dave 63 031.jpg
Name:  dave 63 032.jpg
Name:  dave 63 033.jpg
Old 07-03-2013, 08:49 PM
Semel1's Avatar
Default even more
not sure why cowl fiberglass was repaired by someone
Name:  dave 63 034.jpg
Name:  dave 63 035.jpg
Name:  dave 63 036.jpg
Name:  dave 63 037.jpg
Name:  dave 63 038.jpg
pulling interior to look at fiberglass
Name:  dave 63 039.jpg
Name:  dave 63 040.jpg
looking at birdgage to make sure no rust
Name:  dave 63 042.jpg
Name:  dave 63 046.jpg
Name:  dave 63 047.jpg
Old 07-03-2013, 08:55 PM
Semel1's Avatar
Default the last group
Name:  dave 63 049.jpg
need to line up hood. front end low
Name:  dave 63 050.jpg
Name:  dave 63 051.jpg
Name:  dave 63 056.jpg
Name:  dave 63 058.jpg
Name:  dave 63 063.jpg
Name:  dave 63 067.jpg
Old 07-03-2013, 09:11 PM
pw2006's Avatar
pw2006 pw2006 is offline
Congrats, you will have a blast driving it once it is complete!
Rob
69 Camaro PT project- LS3/4L70e, Budnik's, Ridetech, Speedtech, Wilwood, DSE tubs, 4 link, shortened Moser 12 bolt- in progress
