Old 07-11-2012, 04:18 PM
69x22's Avatar
69x22 69x22 is offline
Originally Posted by kengi1600 View Post
Just came upon your build impressive to say the least thanks for sharing..
kw
Originally Posted by 69Pressurized View Post
Looks like a nice build! Have fun with the car.
Thanks Guys
Old 07-13-2012, 05:00 PM
Stilo Stilo is offline
nice 69 camaro love the over all look
Old 09-21-2012, 07:10 PM
69x22's Avatar
Default Intercoolers
I thought I would share this with you forced induction guys.
When I was in the building stage of this car I took a short cut and went with a cheap ebay intercooler. While trouble shooting on why the car was down on power I discovered there was a 15psi DP across the intercooler due to the air flowing across a long narrow path of core creating the high DP. Bell designed me a intercooler that would allow the air to flow across a wide short core, which lowered the DP across the intercooler and allowed the car to put 835 HP to the tires a 125HP gain by swapping intercoolers. The ebay intercooler was a nice piece for the money it just wasn't a good design for what I had in mind. I hope this makes sense and keeps someone from making the same mistake I made.
Old 11-02-2012, 06:02 PM
69x22's Avatar
Default Crank case evac system
In order to keep oil mist from entering the combustion chamber and causing detonation I decided to install a new evac system. I went with 2 of the new re-designed Moroso breather tanks. The tanks now have an internal baffle with a stainless mesh to help separate the oil. I ran a -12 line from each valve cover to a individual tank. I hope the pictures are not to dark.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 11-19-2012, 10:49 AM
Jim98ta's Avatar
Jim98ta Jim98ta is offline
Love your car!!
Interesting info on the intercooler. I'm running the same type of intercooler that you were it looks like. Amazing you picked up 125 hp from swapping.
Mine has a Vortech T-trim with an LS2 bottom end, LS3 heads. Has a mild cam in it but managed to put down 655 rwhp, 550 rwtq. I wonder if the intercooler is holding it back any... Not that it needs much more especially with a stock bottom end...
Awesome car and thanks for sharing the info!!
Old 07-05-2013, 03:39 AM
69x22's Avatar
I just freshened up the engine a little bit. I Moved the coil packs down by the starter and oil filter. The Stainless Works headers are made out of a lower grade stainless that started rusting out so I sent them off and had them coated. Also had some re-anodizing and hydradipping done here and there.
1957 Chevy 454LSX
Old 07-05-2013, 05:26 AM
Very clean. I like it.
What color or type of coating was done on the headers?
Is that Cartek's Flip Kit I see in there too? I put that system on a Stage 2 Procharged C5Z06. It made a world of difference even with it just being a "stock" 8psi system. Pricey setup but fantastic design.
Old 07-05-2013, 04:34 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
You did a great job,engine sure looks good
Old 07-06-2013, 03:30 AM
69x22's Avatar
Jet Hot did the coating. I told them I wanted the color to look like high quality stainless headers after the have been ran a little bit. I think it was shade #47 or 48.
The flip drive kit was the only way to go using the C6 engine brackets. Im making 16 psi boost without any belt issues.
1957 Chevy 454LSX
Old 07-06-2013, 08:59 AM
It looks nice. I like it with the coils relocated.
