Old 07-08-2013, 08:48 AM
GPR's Avatar
GPR GPR is offline
We block sanded the body than sprayed two coats of SPI epoxy
Brian cleaned the Rod & Custom crossmember getting ready to weld motor mounts.
Getting ready to test fit the FE block with the Canton pan and TKO 600
Making sure the block is in the center, level and has a 4 degree angle so Brian can weld the motor mounts.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 07-08-2013, 11:36 AM
GPR's Avatar
GPR GPR is offline
The transmission mount had to be modified to get the correct angle.
Rusty Gillis
Port Richey Fl
Old 07-08-2013, 05:18 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Looks great Rusty!
I don't know how I missed this build?!
Old 07-12-2013, 12:01 PM
GPR's Avatar
GPR GPR is offline
Brian welded the motor mounts in place. Now when you order a kit from Rod & Custom the motor mounts are already welded.
Rusty Gillis
Port Richey Fl
Old 09-14-2013, 06:04 AM
GPR's Avatar
GPR GPR is offline
The new owner did not like the Eleanor non functional quarter scoops so we cut them off and installed Shelby scoops.
Rusty Gillis
Port Richey Fl
Old 09-16-2013, 05:00 PM
tones2SS's Avatar
Awesome. That is going to look mean and functional.
Old 11-15-2015, 04:25 PM
jarhead's Avatar
jarhead jarhead is offline
just found this searching your posts, any updates?
joe
Semper Fi
My 68 Torino
Old 11-16-2015, 07:47 AM
GPR's Avatar
GPR GPR is offline
No it is on hold at this time.
Rusty Gillis
Port Richey Fl
Old 10-03-2016, 05:55 PM
GPR's Avatar
GPR GPR is offline
This project was on hold for a few years and the owner has decided on a few changes. I'm sorry to say he has decided not to go with the SOHC but is going with an aluminum FE just not sure how big it will be yet. We will also be doing a few modifications to the body.
It is out of storage and back in the fab shop.
The first thing Brian did was finish lining up the sheetmetal
Starting to install the Mustang to Fear gas filler kit.
Welded in place and the welds ground
Rusty Gillis
Port Richey Fl
Old 10-04-2016, 09:43 AM
Glad to see it's back on. I thought this would make for a cool ride no matter what engine choice. Good luck!
