Old 06-29-2013, 03:19 PM
rat_rod_russell's Avatar
rat_rod_russell rat_rod_russell is offline
Updates!
We're making room for lots of tire out back for guys who NEED it and still make it easy to build and fit the 8" ride height without body modifications.
I know a few guys were having trouble with the grid looks so I colored in the sections to make it look correct. Also these are 20" wheels front and rear at the request of the customer to see what they would look like. Again one at 4" and one at 8".
Later
-Russell
PT-57
1957 Chevy Truck, 6.0L LS, T56, STS Twin Turbos, C6 Corvette Suspension, CAD Designed Frame by Hot Rod Jim's.
https://lateral-g.net/forums/showthread.php4?t=20292
http://www.nerdrods.com
Old 06-30-2013, 01:44 PM
Transmission looks like its going to be cake. This is a 4L60E model and its got tons of room. I couldn't find my 4L80 model on the computer.
So the customer asked me to CAD up his wheels to see what they would look like. These are 18" Foose Nitrous II 18" with 245/40/R18 up front and 275/40/R18 out rear.
Also did some pocketing magic and now we've got an even longer shock (we already offered more wheel travel than the major competition.) And I've got miles of room for Ridetech Shockwaves, We area dealer for Ridetech as well so I hope to have that kit worked out soon enough.
Last note, We we'll make these frame rails air tight. You will be able to use the frame as an air tank and no have to mount it anywhere.
Thanks again
-Russell
PT-57
Old 07-14-2013, 02:30 AM
Update time. I'm having to pocket the suspension cradle into the tubing rail on this frame compared to older designs for other cars. Got room for the Air Ride on the back for guys who want to run that way and I'm making room for all the body mounts right now.
PT-57
Old 07-14-2013, 01:23 PM
Hotrod1's Avatar
Hotrod1 Hotrod1 is offline
I wish your frame kit was around before I started my stock frame alteration. Makes me want to build another one. Great work and looks like it is going to be nice finished product. Seems like the price is going to be good for the weld it your selfs out there.
Old 07-15-2013, 08:06 AM
aggie91's Avatar
aggie91 aggie91 is offline
Wow, this it going to be a killer truck when complete. I can see how the Nerd fits into Nerd Rods. You guys have some cool toys to use!
Karl
1965 Chevrolet C10
1982 Chevrolet C10 - My son's Truck - Sunburn
Old 07-16-2013, 11:00 AM
ChuckDriver's Avatar
ChuckDriver ChuckDriver is offline
Nice work Russell! Keep the updates coming!!
JJ
My 1957 project:
http://67-72chevytrucks.com/vboard/s...d.php?t=334552
Old 07-24-2013, 05:05 PM
Getting close, I've got 280 lbs of frame in the computer now we're just dialing in the fine details, making sure all cuts are normal to the surface, giving the tabs the proper tolerances, and working on clearing some small sections on the body and making decisions on where and if we want to do a little cutting on the bed braces. I also whipped up a set of Foose Nitrous II's in 18's for the customer to get a feel for the look on them.
I've got most of the prototype frames spoken for, so it won't be long now!
Later
-Russell
PT-57
Old 07-25-2013, 09:05 PM
Very nice! I really like the changes made to the mounts for the front cradle/clip!!
JJ
My 1957 project:
Old 08-06-2013, 09:41 PM
Detail work now. I'm happy with the shape and we've taken care of most every clearance issue I can think of with these tucks and got the number of parts down compared to the TriFive frame so there will be less welding and will make it easier to assemble but still similar in several ways to give the frame some parallel to the other frames to make guys who have welded one feel familiar with the other.
We've got the Corvette stuff dialed in now but we will have life axle support like the TriFive frame as well. I've sold a few of the truck frames besides this project already but they are all welded frames so I won't need to make instructions just yet. I'll do a time lapse of the second frame I weld for you guys to see how I do it.
You can see two key thinks with this frame in the fuel and brake system support, still working on where and how to place the fuel tank and the 4" tall tubing risers to give the optional ride heights for different builders.
But I know what you all really want, pictures, lots and lots of pictures. So here's your fix.
Later
-Russell
PT-57
Old 08-06-2013, 11:04 PM
groovyjay's Avatar
groovyjay groovyjay is offline
Looks good, would this work with a 56 suburban?
Tags
corvette, pickup, suspension, truck, weld
