Closed Thread
Old 07-16-2013, 08:03 PM
Sieg's Avatar
Sieg Sieg is offline
No kidding....maybe we should transfer it over to the Bad Invisible Finger thread
Fixed!
Now that gentlemen is how you HiJack a thread.
Good point!
  #1282
Old 07-16-2013, 08:08 PM
Track Junky's Avatar
Your welcome. Just dont forget who planted the seed
Gaetano Cosentino
  #1283
Old 07-16-2013, 08:13 PM
fleetus macmullitz's Avatar
If any mod moves this thread it should be Flash.
And it should be done in ...
Old 07-16-2013, 08:26 PM
Not sure that would be appropriate....Rob might end up calling Daves thread Bad Middle Finger
Gaetano Cosentino
  #1285
Old 07-16-2013, 08:59 PM
intocarss's Avatar
Not sure that would be appropriate....Rob might end up calling Daves thread Bad up yours Finger
FIXED
  #1286
Old 07-16-2013, 10:55 PM
FETorino's Avatar
FETorino FETorino is offline
Hey mods....How about moving this great suspension technology stuff over to where it might be more appropriate for others to ask questions about their own cars?
Don't be shy Tracky. Or are you a agent for BMF sent to derail the Torino
Originally Posted by Ron Sutton View Post
I don't think you're jacking the thread. Rob indicated he wants us to have these discussions. (I asked him)
If someone wants to ask specific questions about a different car, then we should start a new thread.
Rob in SoCal
  #1287
Old 07-16-2013, 11:07 PM
Ron Sutton's Avatar
Hey Rob,
Ron
What would you consider Large-ish scrub radius in the case of these 275-315 range of tires?
I have heard that an inch or under can be thought of as zero.
Maybe a little more detail on scrub would be good.
I never created a descriptive verbal scale ... until now.
In my experience & by my personal scale ...
0-1/4" = Zero
1/4"-1" = Very Low
1-2" = Low
2-3" = Moderate
3-5" = High
5-7" = Very High
7" + = Extreme
* But this relative to the situation. When we designed a new Modified chassis that dropped the Scrub Radius from over 7" to under 5" ... we thought of that as "low scrub radius ... for the NASCAR Modified class we raced in on the West Coast.
So, with this new "descriptive verbal scale" ... I need to restate my advice with a slight wording change.
If your PT car has a scrub radius "Moderate or higher" … you need to be careful with how much caster you can put in the car … because caster combined with a high scrub radius creates a “jacking effect” when you turn the wheels. Dynamically, this jacking effect “de-wedges” the car … loading the inside front & outside rear tires more … while also unloading the inside rear tire & increasing the degree the car diagonally rocks & loads the outside front tire.
All of this helps the car to turn better. But go too far … and the car will get loose on entry. This is where track tuning comes into play. If you have a large-ish scrub radius … sneek up on the caster you put in the car … until you get the car “free” on entry … then reduce the caster a tick … or tune something else to allow you to keep that amount of caster, so the car turns well in the middle. But don’t keep a set-up that makes the rear step out on corner entry.
I was having a conversation stating there is a nominal effect on scrub due to height differences in tires. That difference in scrub between a 30 and 35 series tire of the same section width on the same wheel would be pretty minimal and in real world probably insignificant. But with all things it is best not to assume and really dig into what amount of scrub becomes noticeable or detrimental.
I agree with this statement: That difference in scrub between a 30 and 35 series tire of the same section width on the same wheel would be pretty minimal and in real world probably insignificant.
I have had talented race drivers we developed to the nth degree ... with amazing feel & feedback ... that can tell you if you changed the tire 1/4 pound of air pressure, .030" of bump stop shim, which suspension corner stopped traveling 1/16" earlier than the other or if there was extra clearance in your ring & pinion gap ... and that's not even a tiny bit exaggerated.
A Crew Chief/Tuner can have a lot of confidence in those situations. These particular drivers & I won a lot of races together.
And on the other hand ... I've seen drivers that couldn't tell you if they hit a pothole or not. So I think "noticeable" is also relative.
Ron Sutton Race Technology
  #1288
Old 07-16-2013, 11:22 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
[B]Hey Rob,
Rob is probably going to have to worry more about swells than pot holes. Although if he does take his boat out on the road, I'd hate to be in it when he hits a pot hole with his hellaflush rims.
  #1289
Old 07-16-2013, 11:28 PM
FETorino's Avatar
Matt your still mad about that beer aren't you? I knew the pot holes are what led you to the Rubicon set up
So is the Mustang going to be track only?
Rob in SoCal
  #1290
Old 07-16-2013, 11:41 PM
Matt@BOS's Avatar
Hey Rob,
I have had talented race drivers we developed to the nth degree ... with amazing feel & feedback ... that can tell you if you changed the tire 1/4 pound of air pressure, .030" of bump stop shim, which suspension corner stopped traveling 1/16" earlier than the other or if there was extra clearance in your ring & pinion gap.
Couldn't possibly be mad about the beer. DG isn't the only beer snob around here, although he might be the beer snob captain around these parts. Makes sense really. Our cars are kind of the automotive equivalents of beer tastes on champaign budgets.
Closed Thread
