Old 07-20-2013, 06:48 AM
Sonar Chief's Avatar
Thumbs up
Very Nice work on the tubs, going to be much stronger than OEM That is exactly where I am today .... close outs
Thanks for the write up!
Old 07-24-2013, 11:58 AM
Firebird-Geek Firebird-Geek is offline
... I have learned so much from these forums, I just want to give back if at all possible.
I looked at your pics... looks great!
1967 Firebird Convertible
Jarrod
My Build:
https://lateral-g.net/forums/showthread.php4?t=32878
Old 07-24-2013, 12:01 PM
With both inner wheelhouses fit and screwed into place, it is time to remove those NASTY outer wheelhouses.
Jarrod
My Build:
Old 07-24-2013, 12:07 PM
A few more spot welds to drill... and out comes the FINAL rusty pieces off of the car!
Jarrod
My Build:
Old 07-24-2013, 12:09 PM
Started to fit the outer wheelhouses into place... At first I was wondering if I would even get them to follow the contour of the inner wheelhouse... BUT (Like most of these aftermarket pieces) I find that if I just take things slow and tweak it here and there... all of a sudden it starts to fall into place. PATIENCE is a virtue that MUST be kept when putting these old cars back together! Oh... that and A LOT of clamps!
Jarrod
My Build:
Old 07-24-2013, 12:11 PM
Once everything was where I wanted it... I started to put a few screws into the wheelhouses/braces... to make sure everything stays put so I can test fit the quarter panels.
Jarrod
My Build:
Old 07-24-2013, 12:16 PM
Finally Mini-tub project is pretty much done...(just have to be welded in) I will fit the quarter panels and tailpanel first to make sure everything is where it is suppose to be, before I even think about welding it in.
Overall I am very happy with how it turned out... FINALLY I don't see RUST anymore!
PLUS... look at all the extra room I now have to fill up with tire!
Jarrod
My Build:
Old 07-24-2013, 12:20 PM
Here is a BEFORE and AFTER of my mini-tubing project... Now on to the NEXT stage.
Jarrod
My Build:
Old 07-26-2013, 06:18 AM
captainofiron's Avatar
captainofiron captainofiron is offline
Very very cool
with those mini-tubs will you have to relocate the leaf springs inboard?
Old 07-31-2013, 01:21 PM
Originally Posted by captainofiron View Post
Very very cool
Actually I will be installing SpeedTech's Torque Arm system. So it is one less thing I have to worry about!
Jarrod
My Build:
