Old 06-16-2006, 10:15 AM
907rs's Avatar
907rs 907rs is offline
Originally Posted by tyoneal
907rs
Is everything in the picture of parts included in the price? Can you tell me more about what type of engine these are made to fit, and how much power they are set up to make? (Boost) What is necessary to hook them up to an engine?
Where can I find exact specifications?
Thanks,
tyoneal
1. Yes, all of the parts pictured are included, but the compressor housings are unpolished.
2. This kit is designed to fit 1st and 2nd gen small block chevrolets with 23* heads. (265 to 400 c.i. and LT1) It will not fit LSX, 5.3, or 6.0.
3. Included are wastegate springs to run both 6 or 12 psi of boost.
4. Here is a link to the installation guide that'll tell you everything required for install. http://www.bankspower.com/OwnersManuals/96975.pdf
5. Specs can be found on the Banks site.
This is good reading as well.
http://bankspower.com/Twin-Turbo-ima...PowerGuide.pdf
Bill
