Old 08-14-2013, 08:32 AM
mikels mikels is offline
Originally Posted by parsonsj View Post
Me too on PWM control.
So... net net: I need to use a C6 fan controller since it is definitely compatible with the E67. For dual fans, I need to use two controllers, and hope that the E67 can drive two PWM controllers from the same wire.
I've run 2 fans with single PWM C6 fan controller (have to look at total power demands and keep in limits of fan controller) and know that works.
Lou is trying dual PWM modules controlled by single PWM output from ECM -will know soon the success of that route.
Old 08-14-2013, 08:38 AM
parsonsj parsonsj is offline
OK, that's good to know. I'm using the C&R Racing setup with their dual Spal 11" fans.
Is that the fan setup you know works?
John Parsons
Old 08-14-2013, 12:51 PM
Corvette fan is 400W - so at 12.5 V, that's 32 A. So long as your 2 Spal fans are below that current level, should work fine.
Old 08-14-2013, 01:11 PM
samckitt's Avatar
samckitt samckitt is offline
Originally Posted by mikels View Post
Yes - All GMPP crate engine controllers are E67's and can be programmed for fan control in same manner.
Anyone have a PN & source for the connector terminals?
Scot
86 Monte SS
LS2/T56 Magnum
Old 08-14-2013, 08:43 PM
A quick check of the dual 11" Spal fans shows current draw less than 32A.
Looks like I'm golden!
Thanks all!
x2, and looking for cavity plugs too. I've heard reference to "micro 64 connectors".
John Parsons
Old 08-14-2013, 09:03 PM
I have found this site.
http://www.obd2allinone.com/sc/details.asp?item=m5j3
Looks like you can pick up the connectors there. 10 / $2.95.
John Parsons
Old 08-15-2013, 01:44 PM
samckitt's Avatar
Forgot I had a document with some information in it. Like GM PNs for the pins, don't know if it will help finding them or not.
Scot
86 Monte SS
LS2/T56 Magnum
Old 08-15-2013, 09:57 PM
Lous69 Lous69 is offline
Here is where I bought my PWM modules:
http://www.amazon.com/ACDelco-15-808...rol+Module+Kit
You can't open them without damaging them but I was curious to know how the insides of the Corvette version compared to some pics of similar MB units I saw on the net. Here is what the Corvette version looks like inside. They are different than the MB units that look the same on the outside. The MB units do look like they use the same connector as the Corvette units but they will not sell them separately either. I gave up on finding a connector. We are attaching the wires individually with appropriately size female spade connectors.
Old 08-16-2013, 12:22 AM
Thanks Lou! I just ordered the last one in stock.
John Parsons
Old 08-16-2013, 07:15 AM
samckitt's Avatar
I remember trying to find this connector before, seems like it has 4 big terminals & 1 small one, or is there small ones? Is it sealed like a weatherpak connector?
Anyone know the GM part number of the PWM module? Maybe I can have some of my old Delphi co workers track down a connector.
Scot
86 Monte SS
LS2/T56 Magnum
