Old 05-24-2013, 10:35 PM
fleetus macmullitz's Avatar
Excellent progress 'X' .
Old 05-25-2013, 06:10 AM
Rick D's Avatar
Rick D Rick D is offline
Nice job!! I'd say weld the brackets as well.
Rick
Old 05-25-2013, 07:37 PM
for Ratman67 this is where i measured for ya... 115".
Old 05-26-2013, 02:33 PM
Default ECU and DBW
Today I made up a floor mount for the DBW and then made a bracket for the ECU. I have to wait to get my gauges in so I can make sure the ECU location works. If its good clearance wise I am thinking of just welding it to the cowl
Not a lot of room with the AC ducts right there....
Old 05-31-2013, 04:28 PM
Took the day off.. got a good amount done... started with wiring made a lot of progress then decided to make some changes that require weatherpack connectors I dont have... (if anyone now a good source let me know)
Got the clutch master hooked up. I took a slightly different approach. I shortened the rod on both sides, then drilled into the fat end and ran a tap into it. Then ran a Die over the small end. this gives me about .5 to 1 inch adjustment.
started on my gauge panel.. too some 3" exhaust pipe slash cut them @45 degrees this is a rough in it will be much better fitted into the dash before its done. hoping for a factory look when its done.
Old 06-15-2013, 03:07 PM
Default Guages in
working my way through Dash Moc up.
Old 07-27-2013, 02:35 PM
Default Lots or wiring on the bench
completed my wiring on the bench.. now time to MOC it into the car. Fist step Batt.... (BTW Optima no stickers with a new Battery? ) the cutoff is removable goes through the lower bolt hole of the bumper for track days.
Old 07-27-2013, 07:14 PM
The gauge cluster looks Great! The battery install looks good too.
Old 08-13-2013, 05:36 PM
Default Bling
Brown truck delivered some Bling this week
Old 08-14-2013, 12:59 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Definitely some nice work so far,keep it coming
