Old 10-05-2013, 01:37 PM
Looks good, Matt. I like the idea of putting the louvers and gas filler together.
Old 10-05-2013, 01:56 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Do you have a 2 gas tanks? To me, it looks like shots of both sides of the car.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 10-05-2013, 02:16 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by Matt.A View Post
Hey guys, I have pictures to post, and they're not old recycled ones like Rob has, they're new ones, and they aren't of hubs with yellow lug nuts or aluminum blocks with iron heads either.
Hey I was just taking your advice and combing thru the "junkyard"
. Part of the idea behind the car has been to draw on some of the cool original design elements of the early Mustangs and Shelbys and change and or update them without creating a contemporary looking custom build that feels "new." I hope that makes some sense.
one of my ideas was to get rid of the quarter window scoops and replace them with fuel and oil fillers since the car is running a dry sump in the back and a 35 gallon fuel cell that is so tall it can only be fed from the sail panel.
Since I've always one of the more iconic features on the fastback were its louvers I decided to try and add some. After playing with spacing, and the inclusion of the racing style filler that appeared on the Cobra, this is what I ended up with.
Now to figure out how to make a little stainless trim ring that matches with drip rail moldings...
I completely understand your build direction. Kinda like of you went back in time with the knowledge of today and built it with some parts of the past. Maybe that doesn't make sense.
You know what I think of your quarter window fillers already but to be official. Mimicking the feel of the original louvers is a great idea.
Can't wait to see what you come up with for the stainless trim. To date the build is Blue Oval approved.
One side for Gas one side for Oil in the dry sump tank.
Rob in SoCal
Old 10-05-2013, 02:26 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Good eye! I've been thinking that I want this car to be really street friendly, as in, something that is comfortable, safe, and reliable enough to drive to events a few thousand miles away. I also want the car to be a fun driver's car on the track. In order to keep the reliability and streetability I want, I'm not going too radical on the engine. There are manifolds that raise peak power up to 8200rpm, there are larger throttle bodies and there are nasty cams that build much better power in the upper rpm ranges, but get rid of variable valve timing. I don't want to go in that direction, since I want to preserve the most useable amount of low to mid torque and get the best response out of the engine that I can. To that end, I'm sticking to basic items like long tube headers, a little additional port work on the heads and good intake and tune using the factory engine management system. One of the good things about the factory harness is that I should be able to plug in a hand held tuner to the computer, and be able to change tunes in under a minute. See where I'm going with the two fuel fillers.
If the engine is grossly lacking everything that makes it really fast, I can always pull it out in a couple years to sleeve the block, bore it out, and toss in super light rotating assembly with a billet crank and better rods and pistons.
Old 10-05-2013, 02:34 PM
FETorino's Avatar
Sneaky. I just thought one was for the dry sump tank. Maybe your were talking about the customers car.
Rob in SoCal
Old 10-05-2013, 02:50 PM
Matt@BOS's Avatar
Yeah, that description gets at what I'm trying to do. I'm trying to keep the number of overtly modern touches like billet tail lights, carbon fiber bumpers, or other finish details like shaved door handles, modern mirrors or new school steering wheel and gauges to a minimum. I want it to be a little bit like how Steve Strope designs his cars, except I want this thing to be functional for me, which means a new engine and nice seats.
Speaking of gauges, I need to give Speed Hut a call. I want some gauges very similar to yours, except I want a yellow tach that reads 7500 rpm at 12 o'clock.
See, your recycling of the junkyard has been useful both to me and Speed Hut.
Oh, and I think the dry sump must have been in regards to the customer's car. the Boss 302 engine uses a huge road race wet sump. I haven't heard of poor oiling on the Coyote motors like I've heard about on LSs. I know the Grand am Mustangs are still running wet sumps so they must not be too bad.
Old 10-05-2013, 04:15 PM
Matt, did you see Maier just came out with flared front fenders for 65-66 that fit 315's?
Good to know you are the official rep for all things Blue Oval.
Old 10-05-2013, 05:15 PM
Matt@BOS's Avatar
I think I can fit 315s on the front of my car, but I'm going the hellaflush route and since I'm planning on running street tires, I'm thinking of using either the 295 Rivals or the 285/30 Dunlop ZIIs. It's probably the rear that would need the wheel houses and/or frame rails modified to fit the 315 without rubbing.
Old 10-05-2013, 05:25 PM
Nice. What size rears you gunnin for?
You know Rob will not approve on behalf of the Blue Oval camp unless they are a 345 at a minimum.
Old 10-05-2013, 05:34 PM
carbuff's Avatar
carbuff carbuff is offline
No kidding!
