Old 10-17-2013, 07:17 AM
Sonar Chief's Avatar
Post
Originally Posted by will69camaro View Post
I got there a little before he did. one spot he showed and it was obvious (i had already seen it). The other I had carefully inspected prior to him coming in and I showed him that one.
Interior/cage/tail panel/engine bay will be painted prior to me taking the car back. All semi flat black. Bottom will be done as well in Lizard Skin/Flat black.
William
Just a couple words of caution .... Lizard Skin is an awesome product if used correctly. Read "spraying minimal thickness is 0.040" wet over two coats" and that's is almost impossible to judge after it's dried (unless you cut out a chunk and measure it) .... just saying, don't want you to get something you didn't pay fer.
Good luck .... car is come a long way!!!
