Old 10-28-2013, 03:02 PM
67XR7's Avatar
67XR7 67XR7 is offline
Default Tire Rack, Tire comparison Video
Anyone else watch this?
https://www.youtube.com/watch?v=kASM04zuHlo
Not sure the results are 100% accurate, I have a bunch of questions regarding the test.
-What order were the tires tested in?
-what time of day were they each tested at?
-outside temp during each test?
-why is there no video of each independent test?
I guess I find it hard to believe that the dunlop was faster then the other popular tires most fast auto x cars are using. its also weird that the winning Tire happens to be a tire that tire rack sells.
1965 Chevelle, Pm me if interested in wheel tool rental
Old 10-28-2013, 04:01 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
I was skeptical too....until I found out Woody did all the driving at their facility under controlled conditions. I am more interested in the data from the test that they pulled from the logger.
The Dunlop winning is not a surprise, it is a VERY good autocross tire as is the RS3.
Donny
Old 10-28-2013, 04:05 PM
GrabberGT's Avatar
A second faster than a BMW.
Chris
Its not a Vega!!!!
Old 10-28-2013, 05:27 PM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
You want the best? Look no further! Top of the line!
Pos-A-Traction
Radial Twister
Last edited by Twoblackmarks...; 10-28-2013 at 05:32 PM. Reason: Better description.....
Old 10-28-2013, 05:47 PM
I wonder how much better all of these tires would be if they were allowed to build some heat in them before an autocross run.
Old 10-28-2013, 05:48 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Attachment 42781
Pos-A-Traction
Radial Twister
that reminded me of this.
Scott from NJ
Old 10-28-2013, 06:11 PM
Long lasting for shure.. Theese in the pic are from 76`.. Same Company?
They had cooler names before atleast, probably descent in their time too, I was told that even when this were New, you could do everlasting burnouts without them wearing at all.. Against better knowledge, I have used them (on two cars.....) in the front, and if you drive fast you can rapidly steer, and all you hear is "Grrrrr" from the tires and you just og straight Ahead.. They are killer in the wet, literally..
Modern cars should have such tires, maybe then People would drive nicer and calmer.. He..He..
(They are actually totally "fine" I have kept up With an Golf GTI on twisty turns With an 2-gen.. But there are smarter tires to use..)
Here there is many who use Pirelli P-Zeros, one of the more "serious" types
Old 10-29-2013, 09:57 PM
LS7 Z/28 LS7 Z/28 is offline
Thanks for posting
What I find funny is how they did the test with the Pro Touring / G Machine crowd in mind, yet the top two tires are not available in a size larger than 285 in 18''. The Hankook has a 305 19'' but that's it.
In my opinion that basically throws them both out.
I think a large majority of the guys with ProTouring cars are running larger rear tires. 315,335,345...
So in my opinion the BF Goodrich Rival proved it's worth and Hot Rod basically proved nothing.
Old 10-30-2013, 12:40 AM
here are your answers:
-What order were the tires tested in? who cares
-what time of day were they each tested at? who cares
-outside temp during each test? who cares
-why is there no video of each independent test? who cares.
Old 10-30-2013, 12:41 AM
the previous post was brought to you by Dunlop.
