Old 07-31-2013, 11:58 PM
jarhead's Avatar
jarhead jarhead is offline
dang this has been an interesting read! You have skills!
Congrats on the autocross
Love old Falcon's, had two myself.
joe
Semper Fi
My 68 Torino
Old 08-01-2013, 06:44 PM
craig510's Avatar
craig510 craig510 is offline
Thanks.
I have some new parts that will be going on in the next couple weeks / months:
+ 1.25" Ridetech hollow swaybar
+ Modified Bilstein shocks with adjustable Penske canisters (On loan from Mike Maier)
+ Optima Battery
+ 20 gallon fuel tank with Jag filler cap mounted passengers side behind the rear window.
Old 08-01-2013, 09:05 PM
coolwelder62's Avatar
Just Awesome.
Old 08-01-2013, 09:18 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Very cool build. If I'm ever at a show you are at, I gotta check this thing out!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-12-2013, 10:32 PM
craig510's Avatar
The Ridetech bar was a small diameter than described (basic 1.125" mustang swaybar). The posi links only have a 2500# load rating, but it should be ok, hopefully they get loose or crack before failure. I can always install larger ones or 1/2" heim joints at a later date.
I am going to cut off the end of the swaybar and add some collars to make it adjustable and increase the rate. By mounting the link to the upper arm it looks like I can get at least a .64 motion ratio and about a 440lb/in wheel rate.
If this bar is not stiff enough, I am going to cut up my 1" bar and weld or braze in a 1.375 x .188" wall chromemoly tube to replace the center.
[IMG][/IMG]
Old 09-02-2013, 10:13 PM
craig510's Avatar
This is a little late in coming, but home ownership and a new puppy have been getting the best of me. Spent 5 hours this weekend breaking up a 7'x7'x5" wire renforced concrete spa pad the hard way with a 10lb sledge. (It is all to make way for my new shed)
These are from last weekend. Torqued up the wheels at 9:30 PM Saturday night and was at the track 8:00 AM on Sunday, then went to a wedding at 3:00 PM.
It took a couple tries to find a spot to mount the Mikes special Penske canister shocks.
Even on setting 1, the shocks feel stiffer, but they have a more plush feel. I think that it has to do with the slower ramp up of the nitrogen pressure with the larger remote reservoir. I also mounted my RideTech bar (using my old end links). I must say, I am dissapointed with the Ford "Muscle Bar." It is just a run of the mill 1-1/8" Mustang bar, came with lower quality mounting hardware, and would not fit the "Posi-Link" adapter without quite a bit of filing (which is no fun on spring steel). RideTech makes some excellent product, but this is not one, more of a fair quality product at a premium price.
I played quite a bit with tire pressure, working on getting good front and rear temps. I got my front pretty close, but I still had a hot center on my rears. At least I have a better starting point.
Some good videos showing the wheels. The geometry looks pretty good, but I think I am going to lower my roll center a little more and add some more front bar.
RideTech vs Grab a Tracks bar.
Normal crush bends, and not too round at the bushings.
At least now, I could use the Posi-Links
Had to work on the brackets to get them flat and not pinching the bushings.
The canister shock had to go in from the bottom, and I had to shorten my adjuster so that the TEE at the top would fit.
Old vs New style mount, I modified my mount so that it can mount on either side (this let me point both shock canisters forward).
This one rubbed the tire at bump and full lock.
Finally got it.
Street vs Race vs Race Special
Old 11-14-2013, 10:30 PM
craig510's Avatar
Default Scottsdale or Bust
The falcon made the 750 mile drive with no issues. Ready for the big show tomorrow.
Old 11-14-2013, 11:21 PM
FETorino's Avatar
FETorino FETorino is offline
Good Luck
Rob in SoCal
Old 11-15-2013, 06:35 AM
Passed you and Maier yesterday in my hauler. Honked but you couldn't look up high enough to see me waving.
See ya today!
Old 11-15-2013, 06:57 AM
craig510's Avatar
Cool. They won't let me in for another hour hoping to get a pit stall
