Go Back   Lateral-g Forums > Events > Track and Driving Events
Old 11-17-2013, 02:37 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by DaleTx View Post
What are the three components you are referring to?
Harness/roll bar and front suspension geometry the latter should be handled this winter. Rear drums and gear ratio are my other anchors.
Old 11-17-2013, 03:04 PM
DaleTx's Avatar
DaleTx DaleTx is offline
The harness and roll bar is a must...
I do have a set of 3.55:1 rear gears for a 12 bolt if that would work for you. I'm wondering about the autocross event... do most guys run autocross courses in one gear (no shifting)? second gear?
I need to learn more about car set up and driving technique for autocross...
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 11-18-2013, 07:54 AM
GrabberGT's Avatar
Harness and roll bar? I thought it was not necessary but encouraged. Even if you do not have these items, Id still go and have a good time. Just dont drive all out on the road course. Just have fun with it and get a feel for what your car is doing.
Autocross depends heavily on the course and your gearing. When I had 3.55 gears I'd stay in first but could have used second. I changed to 4.11 and am not using 2nd almost exclusively.
Chris
Its not a Vega!!!!
Old 11-18-2013, 10:40 AM
I think he means it's just a really good idea vs required to run.
Chris, I got to check out your car at SEMA but you weren't around so didn't get a chance to say hello. Really cool car and extra points for (1) driving it all the way there, and (2) NOT being a Camaro.
Old 11-18-2013, 11:22 AM
Sieg's Avatar
Roll bar to mount harness belts, belts to secure upper body movement. Secondary benefit.........safety.
Never If it's just a casual competition I can usually restraint myself to 9.9/10ths.
Old 11-18-2013, 10:20 PM
I texted Jimi today to volunteer to work all of the west coast events. I don't have any cars that qualify but love to watch all you guys make a mess of yours!
Hahahaha
Old 11-18-2013, 10:44 PM
DaleTx's Avatar
Hahahaha
I can't wait to run at PIR... be sure you don't stand on the outside of any corners! Lol
Mario Andretti
Old 11-19-2013, 07:36 AM
Hopefully he says "thanks, but no thanks."
Old 11-19-2013, 07:47 AM
DaleTx's Avatar
Thanks Chris… I was trying get a general idea on the car set up for the autocross… and that helps. I have never run an autocross event before. At the Optima Challenge autocross course it looked like most guys were shifting into second and then leaving it there… but I couldn’t tell for sure. Hopefully my 3.73 gears will be ok. I may have to shift into first if the course is very tight.
On the harness and roll bar I just meant it was a good idea. The USCA website did not say that a harness was required. When I first started out I ran the stock seats and three point belts. Running with the harness and some good seats with side bolsters makes it so much better (not getting tossed around) and safer.
Mario Andretti
Old 11-19-2013, 07:58 AM
Sieg's Avatar
Won't happen........the man takes his volunteer work seriously.
Jimi should just get him a podium and sit back and relax.
