Closed Thread
Old 12-01-2013, 11:54 AM
INTMD8's Avatar
INTMD8 INTMD8 is offline
Bob
As of this afternoon the Quicktime is now exactly the same height as the frame rails from the ground.
Nothing will be lower than the frame rails.
You aren't making it easier to build headers! What size primaries, 2"?
  #1722
Old 12-01-2013, 12:15 PM
fleet's Avatar
fleet fleet is offline
Nice slicing Rob.
Reminds me of the Bass-O-Matic's slicing power.
Old 12-01-2013, 07:08 PM
intocarss's Avatar
^^^^ Cosmo going old school
  #1724
Old 12-01-2013, 07:24 PM
Panteracer's Avatar
Default 1969 Torino
So wondering about your dry sump
I help my buddy with his Can Am car
and we heat the oil for 20 minutes before
we start it. So you have a smaller tank
Like the LS motors??? Not sure how it works
with a street car??
Panteracer. NorCal Bob
  #1725
Old 12-01-2013, 09:33 PM
FETorino's Avatar
FETorino FETorino is offline
Jim You know nothing on these cars is easy. 2"/2.25 stepped primaries. I guarantee they will not be one piece units.
Originally Posted by compos mentis View Post
Nice slicing Rob.
Were you at the shop watching me cut it. Cuz you are probably spot on with that clip.
with a street car??
Bob
My tank is a used Peterson ALMS unit, 4 gallon capacity. Here is one of GWs favorite blurry photos of it.
On the dyno 12 quarts got the oil level where we wanted it. In the car the lines will be longer so I'm sure I'll be adding a quart or more.
You can start it without pre heating. Warm up time with 12+ quarts of oil may be a little while. I'm going to run a C&R radiator with a heat exchanger for the oil. We'll see what the morning warm up time is like without pre heating. I will have a heat probe in the tank and will add an external heat band if needed.
So as of now I don't know any more about the oil warm up than you.
Rob in SoCal
  #1726
Old 12-01-2013, 11:08 PM
Lenie's Avatar
Lenie Lenie is offline
Bob
Been there done that!
Lenie
  #1727
Old 12-02-2013, 09:58 AM
Ron Sutton's Avatar
Ron is a wealth of information and a very gracious and helpful guy. I am hesitant to speak with him anymore because I always come away from the conversation wanting to change something.
That will teach you !
Ron Sutton Race Technology
  #1728
Old 12-02-2013, 10:02 AM
Ron Sutton's Avatar
Bob
My quicktime bellhousing is cut the same. Did it in the mill.
  #1729
Old 12-02-2013, 10:51 AM
Ron Sutton's Avatar
Hey Guys,
Rob & I already discussed this on the phone, but I figured I'd catch up the details for anyone following along.
Ron
You didn't expect a technical discussion with this crowd on this thread did you
No ... not in my wildest dreams.
Great seeing you at the Lat G party and at Optima. Sorry I missed Phx.
It was great meeting you and a lot of guys on from Lat G. The party was fun.
Even my racing buddy Randy that tagged along had fun.
Time for some brake tech
Previously on the forum you had run some brake calculations for me that are now slightly out the window. As I progressed on my engine setback project I abandoned my swing pedals and dual master setup. Buried a few post back under the ribbing you can see I posted about it.
I purchased a set of floor pedals but as with all floor pedals their ratio is limited. They are 5.75 to 1 at best so using the 100lbs std driver force there is an obvious loss in clamping force.
My floor pedals have a .875 and .813 master cylinders. Intuitively I would think with the lower pedal ratio of 5.75 maybe I should be running the .813 master for the front and a .750 for the rear to raise the line pressure and achieve a total braking force closer to 4000.
I also understand we could achieve more braking force through the use of a higher COF pad.
Intuitively doesn't make for much of a scientific discussion so plugging in the master sizes and new pedal ratio into your chart would be the best starting point for a discussion.
I also understand that setting my overall suspension parameters, either tweener or high travel, will also dictate what brake bias 65/35 or 70/30 we are targeting.
Based on the front suspension travel I think you'll end up with, you will probably need around 70% front braking.
The cool thing with adjustable bias in the pedals is you can fine tune the bias to perfection without giving up any total braking force. (Unlike a proportioning valve which reduces braking force).
Changing from the planned 6-1 pedal ratio to 5.75-1 is a small change. Only a 4% reduction in fact. That does not dictate a MC change, as that would produce a much larger increase, of about 16%.
As you can see from my calcs below, dropping 1 step on both M/Cs puts it over 4000# of braking force, which in my experience is too much braking force for a mid-to-high travel suspension strategy. I think you'll find 3562# is plenty of braking force.
On another note, I do these calcs based on 100# of leg force at the pedal. In the racing world, we "tune & adjust" braking to fit the driver all the time. 100# is just a starting baseline #.
For smaller drivers ... I have raced cars with champion female drivers that weighed 100# and male drivers as young as 12 that weighed 72# ... I designed a brake package that decreased the amount of leg force required.
We don't want the pedal to be too hard to push, or you wear the driver out over long races ... and you don't want it to be too easy to push ... making it too easy to lock up the brakes. In then end, it's all about tailoring it to the driver.
For those of you who haven't met Rob, he's a big fella. So Rob, I'm thinking you pushing the brake pedal with 100# of force will be easy. I feel we need to be concerned that we don't make the brakes too easy for you to lock up.
Let's start with what I originally outlined but with the 5.75-1 pedals ... making 3562# total braking at 100# of leg pressure ... and see how the braking characteristics fit you. We'll "tune & adjust" to your tastes after you and the car get up to speed.
  #1730
Old 12-02-2013, 11:28 AM
Panteracer's Avatar
Default 1969 Torino
Rob,
I think if you only have 12-13 quarts with the heat
exchanger you should be ok.. My pantera has 10 quarts
and my water to oil cooler actually helps warm things
up fairly quickly.. I was worried about it when I autocrossed
it a few times as oil temp does not get that hot on
your first runs.. but the gauge told me it works
Panteracer Norcal Bob
Closed Thread
