Old 12-04-2013, 04:49 PM
frojoe's Avatar
frojoe frojoe is offline
Perfect, thanks Blake!
One more question for you SpeedTech folks.. what's the maximum backspacing you can fit on the regular curvy Speedtech (not high-clearance) UCA & LCA, with factory drum spindle? Maybe if you don't have that, the max BS for regular arms with AFX spindle?
Vancouver misses you guys!
Cheers,
joe
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 12-05-2013, 09:09 PM
v8s only's Avatar
v8s only v8s only is offline
speedteck regular control arms and rideteck truturn I have 18x10 wheel 6 inch back spacing at full lock the rim slight touches the control arm so a 5.75 back spacing should be perfect
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 12-06-2013, 09:08 AM
frojoe's Avatar
Awesome, thanks for the added info v8s only!
Joe
Old 12-06-2013, 02:27 PM
Blake Foster's Avatar
Keep in mind the Nova has narrower outer fenders than the Camaro as well.
by about an 1"
mine are 9.5 with 6.5 bs (on our Subframe) and the inner fenders are HEAVLY modified out by the fender as are the fender lips
Blake Foster
www.speedtechperformance.com
Old 12-10-2013, 06:05 PM
frojoe's Avatar
by about an 1"
Awesome, thanks for the info Blake. And yes, I'm aware of the massive modification needed, but that's no big deal considering all the other stuff I'm done to get it to this ride height.
Cheers!
joe
Joe
