Old 12-27-2013, 09:49 AM
HEEP's Avatar
HEEP HEEP is offline
any pictures of that process? I am about to start on that on mine. I havent seen anyone actually post pictures.
thanks,
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
Old 12-27-2013, 11:29 AM
Wissing72's Avatar
Wissing72 Wissing72 is offline
thanks,
Bill, I don't at this moment. I will call the body shop and see if they do. I saw that that t.v. show Musclecar on Spike is doing a 442 and did the same process.
In short, if you look at the tubs from the trunk you would cut the inner tub where the 2 are welded together in the center drill out the spot welds at the trunk, remove amount of metal from floor, install tub, and fill center of tub with new metal. This is a short version and there is more to it than that, but I am at work...
I am sure someone will chime in about it since most of the cars here have had it done to some extent. Try a search as well, and I will try to get more info and some pics if I can.
Hope these come through. I found these on the post from Ironworks Chevelle build. We didn't remove the back panel the way they did. Hope they don't mind that I pass the pics along.
https://lateral-g.net/forums/show...light=mini+tub
http://i616.photobucket.com/albums/t...28-2012004.jpg
http://i616.photobucket.com/albums/t...28-2012006.jpg
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
Old 12-27-2013, 07:22 PM
Precision Classics Precision Classics is offline
I would like to thank Chris for the opportunity to build this car, and giving me the freedom to use my ideas and imagination. I have put a lot of heart and soul into this car and loved every minute of it
Eron
Precision Classics & Collision
Old 12-27-2013, 09:26 PM
Wissing72's Avatar
Eron
Thanks Eron. Glad you jumped in on the forum and welcome aboard! Your ideas and imagination have been great, you were able to listen to my initial plan and ran with it. I appreciate it.
Chris
Old 12-31-2013, 04:08 AM
HEEP's Avatar
Chris,
Thanks for those links. I had seen the one from Ironworks, man I love that car. He has done inspiring work. I'm just about to the point of cutting, just trying to see others.
Keep up posting updates, you know the Chevelle guys need to stick together
thanks,
Bill
My Build Thread;
Old 12-31-2013, 07:00 AM
I don't understand the layout of the shop. Is it 42 wide and 20 deep? One single garage door? Or is there another door from where you're taking the pics?
I used to do everything in a 40 deep by 22 wide "4 car" garage.... I'd do my projects in the winter -- everything parked outside or in the trailer (or temporary storage) and put the car up in the center of that space so I could work all around it. It took some effort but I'd get 'er done!
Nice space to have that's for sure!!
Old 12-31-2013, 09:45 AM
Wissing72's Avatar
Greg, its 42' deep and 20' wide. There is a 14'wide main door on the front (I was standing in the door way when I took the pic) At the back and to the right there is a smaller 10'wide door and at the back left there is a bathroom. The part that I don't like but is required are the "wing walls" and California code requires that every 25' the building "boxes" so with the width that I have they get in the way but I will try to put them to use. The previous owner built it as a boat/r.v. garage.
I will probably do the same as what you said and put the car in the trailer when I am working on other projects. Of course with 2 little ones it will probably be turning into bicycles and motorcycles soon.
Chris
Old 12-31-2013, 10:11 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
.... you know the Chevelle guys need to stick together
Tis true, but the Camaro guys have us out numbered like a bajillion to one.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 12-31-2013, 12:22 PM
Wissing72's Avatar
A photo is probably better than the description.
Chris
Old 12-31-2013, 12:23 PM
Wissing72's Avatar
Very true.....
Chris
