Old 01-21-2014, 01:08 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Originally Posted by coolwelder62 View Post
Pretty cool. It's hard to bead roll a panel that long in 1 pc.
Thanks for props Scott! I wish I was that good though! I actually did it in 2 pieces. My bead roller only has a 24" throat on it. I flanged both sides so they overlap and sit flush with each other. I included a shot when I was doing the passenger side.
Brent
Old 01-21-2014, 01:26 PM
Lateral-g Moderator
Glad to see it's coming along big boy.
Old 01-21-2014, 01:34 PM
Ricochet's Avatar
Thanks Stuart! As the saying goes...Bit by bit the little bird builds it's nest!!
Brent
Old 01-21-2014, 02:12 PM
Lateral-g Moderator
The way mine is going I'm making sure my rear view mirror can hang a handicapped parking placard.
Old 01-21-2014, 02:14 PM
Ricochet's Avatar
Now that's funny chit! I'm not far behind!!
Brent
Old 01-22-2014, 09:50 AM
3Deuce 3Deuce is offline
Sounds familiar! My car just gives me sad faces when I'm in the garage for something now.
Old 01-28-2014, 08:34 PM
Ricochet's Avatar
Default Minor Update
OK, a little productivity for today. I was able to get the passenger inner wheel well done and tie it into the in the side panels. Took some time to get it all done. Hard when you have a rolled angle at the fender & it remains flat at the frame. I also was able to get the tranny cooler mounted. I was running out of options up front. So I opted to mount it behind the pass front tire. Should get plenty of air there. It's a stacked plate which cool extremely well, plus I went one size larger from their recommendation. They didn't think it would be problem with the location. I plan on using stainless mesh in the openings to protect the cooler from any debris. The inside of the wheel wells and panels will all by done in Raptor bedliner material. Now off the driver side which I already have a good jump on.
Brent
Old 01-28-2014, 09:25 PM
Sieg's Avatar
Sieg Sieg is offline
Brent - Shot in the dark, depending on the gauge you might consider backing up the stainless mesh with expanded metal to provide impact resistance. 3/4 minus rock at velocity could cut the stainless.
Old 01-30-2014, 01:42 PM
youthpastor's Avatar
Um ya....I'm going to have to point cleco #'s 3 and 17 on the left side are off by 3 degress, not sure it will pass 200MPH.
WORK LOOKS AWESOME, STILL MY FAVORITE '55
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
