Old 01-30-2014, 10:34 AM
Sieg's Avatar
Sieg Sieg is offline
Is it a wet saw??
PS -- Build a new shop with a smaller house -- houses are overrated.
Yes it's a wet saw.
My garage plan was ruined by a public utility access on the east side of my property. Original plan was to have a 3-car drive-thru garage with the back drive-thru portion (15x25) being shop and layout space. That would have increased the footage to just under 1200 s.f.
Old 01-30-2014, 04:11 PM
Wow very nice! I "need" one of those .
Congrats on the unload. That looked like fun.
John
'71 Nova (Build thread)
FFR Roadster
Old 01-30-2014, 09:44 PM
Sieg's Avatar
Thanks.......I have further appreciation for what the Egyptians accomplished.
Old 01-30-2014, 09:56 PM
Sieg's Avatar
One thing leads to another........with the larger saw and already having a space issue every item sitting on the floor was moved and reconfigured today. I also reworked the left side which allowed me to move the car over gaining a valuable 12" in the work area. It feels spaciously cozy now.
Old 01-31-2014, 07:19 AM
Even if you had 100,000 square feet... the minute something "new" comes in -- everything gets re-configured. Can't tell you how many times I've done that shuffle. It can actually be fun - and forces a guy to think what's really needed or how to store stuff - or to build something to make the shop more efficient.
Old 01-31-2014, 07:45 AM
Sieg's Avatar
Isn't that the truth. The business had 15,000 s.f. and I fought maximizing lack of space issues every week.
Yesterday was definitely 8 hours of high quality shop time which I thoroughly enjoy!
I might just compound it today. Dinking around the shop with the dogs and listening/watching the Phoenix Open golf tourney sounds like a plan!
Old 01-31-2014, 08:25 PM
rwhite692's Avatar
Very nice, Scott. I unloaded my JET 7x12 yesterday (as you saw on FB). Mine is more basic (belt not direct gear drive) and is not a swivel type. I am really looking forward to putting it to use. Did a few test cuts and Indeed the coolant makes cutting so much nicer. I ordered up some good bimetal blades and coolant concentrate also.
And oh yes, these things are heavy.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 01-31-2014, 09:32 PM
Sieg's Avatar
Rob that saw is all you need unless you're doing a lot of miters which is the reason I went to the swivel head. Mine cuts like a house of fire compared to my small dry saw. I installed the 8-12 blade tonight and will probably order a 10-14 and straight 14 as my go-to blades. Be careful when changing blades and setting the tracking, the tensioning/tracking system is goofy and sensitive. At least thats my initial impression. Tightening the tensioning bolts has a major impact on tracking. I learned the hard way and cut through a section the backside blade guard near the top wheel. Only took a couple seconds with the stock 6-10 blade.
So I put the saw in neutral and manually spun the wheel to set tracking.
FWIW - I'm also going to pick up some rem pieces of solid round stock to have on hand for conditioning new blades.
Old 01-31-2014, 09:45 PM
rwhite692's Avatar
Thanks for the tips, Scott, I'll watch out for that. Conditioning the new blades is a good idea, I have a few chunks of 3" solid round plain steel I can make some "baloney slices" from. One of the reasons I bought the saw is also for being able to cut down round stock to put it in the lathe. There is a really great metal scrap yard down in San Jose that I get to visit once in a while, It is loaded with cut (much of it new) remnant materials and now, having this saw around opens up a lot more possibilities.
My Lateral-G Page
My Shop Build:
Old 02-01-2014, 12:04 PM
silvermonte silvermonte is offline
Are these saws able to stand vertically and use as a sort of table band saw? I can see how the saw can stand vertical but I have no idea where a table would come from. I want this function to make brackets so Im looking for more fuction without having multiple tools. If possible can someone take a picture please.
