Old 12-16-2013, 09:48 AM
MikkoV MikkoV is offline
Transmission issues with this, i got good deal from GM T56 so bought one. And got also good price from that Getrag box so...
So whatīs easiest and most cost efficient way to mate GM T56 with my Hemi
Viper bellhousing bolt pattern matches to Hemi bisedes two top holes? But input shaft is too short with that?
Chevrolet Camaro LS3+T56 "-70" Drift & Track
Dodge Charger 500 -70 ???+??? Pro-Touring style project
Opel Manta A 3700 -71 Euro muscle.
Old 02-01-2014, 11:28 AM
Does bellhousing from challenger srt8 fit to this? bellhousing fron tr6060 fits to t56 right? Is there big lenght difference in input shafts?
Small progress with car otherwise also
Old 02-01-2014, 05:09 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Pretty sure Quicktime has a bellhousing that mates a GM T56 to a Gen III hemi.
Try calling Mark Bowler at Bowler Transmission, he'd know or be able point you in the right direction
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 02-02-2014, 01:56 AM
Yes, this seems to be the one ->
http://www.jegs.com/i/Quick+Time+Bel...-8078/10002/-1
But thatīs over 500$ everywhere, plus ~100$ shipping to here Finland.
Dodge OEM http://www.moparpartsoverstock.com/p...8061184AA.html
Is lot cheaper, and personally believe that oem product is more precise for fitment.
Old 02-02-2014, 04:02 AM
Discovered interesting thing.
Lakewood rm-8077 Hemi to Chevy LS-T56 / Viper T56 (How can they sell it to both, different lenght input shafts)
Lakewood RM-8078 Hemi to Ford T56
http://lakewoodindustries.com/mopar6...t56-viper.html
http://lakewoodindustries.com/mopar6...t56-chevy.html
Jegs RM-8077 Hemi to Viper T56
Jegs RM-8078 Hemi to LS1 T56
http://www.jegs.com/i/Quick+Time+Bel...-8077/10002/-1
Summit RM-8077 Hemi to LS1 T56 / Viper T56
Summit RM-8078 Hemi to Ford T56
http://www.summitracing.com/dom/part...8077/overview/
http://www.summitracing.com/parts/qti-rm-8078
Amazon RM-8077 Hemi to Viper T56
Amazon RM-8078 Hemi to LS1 T56
http://www.amazon.com/Lakewood-RM-80...ywords=rm-8077
http://www.amazon.com/Lakewood-RM-80.../dp/B004DCEMTG
There is somesord of mix up in this, but could it be that 8077 requires Viper input shaft or custom flywheel and pilot bearing spacer.
And 8078 is direct fit with LS T56
And, Rm-8081 for Hemi and Dodge TR6060, for new Challenger that sees to have separate bellhousing unlike Chevy TR6060. If you look picture, seems that transmission bolt pattern is same that older T56 boxes, but what would be the lenght? Canīt seem to find that dimension picture anywhere.
http://lakewoodindustries.com/mopar6...9-10chall.html
And again, reason i investigate this, Dodge bellhousing
Is A LOT cheaper
Old 02-02-2014, 04:40 AM
rjsjea's Avatar
Pretty sure the Dodge OEM one will not work
RobS
Old 02-02-2014, 04:46 AM
http://forums.corral.net/forums/gene...-t-56-a-8.html
Found this thread, according to that. Dodge tr6060 bolts to t56 bellhousing
Old 01-01-2015, 05:38 AM
I eventually get quicktime bellhousing, now had time get back to this. I builded another dailydriver -70 Charger at meantime
Hemi...
Its pretty tight (impossible?) fit with steering box and drivers side exhaust manifold, any ideas which location should i move engine? If i remove A/C compressor, i can take it further back.
Itīs now about 1.5" on right of centerline and oilpan at k-frame level. How far back are these ususally mounted? Transmission tunnel seems to need quite a bit modification for T56.
Iīve been playing around with idea of fabricating bolt on subframe add-on for steering rack, that would solve issue with steeringbox, and couple other problems too.
Old 01-01-2015, 04:12 PM
Wish I could help, Mikko, but I don't know much about Mopars. I'm glad to see you still working on it. The orange one is nice as well. Good luck with them.
Old 01-01-2015, 08:25 PM
68Cuda 68Cuda is offline
I believe 1.5" offset is correct for B-Body. For the front / rear location and height, make sure you are clearing the steering center-link lock to lock. Do you know the location for the stock engine? I have a Mopar A-body, so I can not be much help, it is a little different. If you move the location of the engine it affects many other pieces, it is a big jigsaw puzzle.
Michael
Plano, TX
1968 Barracuda Notchback
Body & Paint:
http://www.forabodiesonly.com/mopar/...dy-2014.10252/
Engine:
http://www.forabodiesonly.com/mopar/...ictures.10230/
