Originally Posted by pimlico
But then again, isn't the GTR 1/4 mile only 11 seconds? It's pretty easy to a 1st Gen Camaro into the 10s with stock LS engines.
Why such a tall order?
Your posts seem to be all over the map. Comparing completely different platforms of cars is like comparing a Sprint Cup car to a Kia.
An 11 second 1/4 Mile is far from slow. It's very difficult to make a street car run 10 seconds. It takes a lot of tuning and chassis setup. I'm not sure which Stock LS powered first Gens you are seeing running in the 10's because that would be incredibly difficult even if the car is completely set up.
The GTR is meant to perform in all aspects, the same as a ZO6 or a ZR1. Most of the people on this site are concerned with handling more than anything. When they are referring to "the track" they mean a road course.
As far as you putting 550-650HP into a First Gen. It will certainly be more than a "gut crusher" as you said. Hopefully you are planning on 335 or 345' rear tires to help with traction.
I'm not sure what your experience is with power on the street but 450 HP in a well set up car can get you into trouble in a hurry. Hopefully you are planning major suspension and braking upgrades as well.
