Old 01-30-2014, 08:22 AM
Efi69Cam Efi69Cam is offline
Default seamless vs welded stainless tubing
Looking to order some tubing to finish up my fuel lines.
Can I use .020 wall annealed welded tube if I'm going to 37' flare it, or do I need thicker wall?, seamless?
Old 01-30-2014, 12:05 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
You need seamles tubing, welded tube will have booger on the inside and you will _never_ make it seal.
I usually use .035"
Donny
Old 01-30-2014, 02:56 PM
Thanks. seamless it is, I do need it to seal.
Old 02-05-2014, 08:09 PM
bentfab's Avatar
bentfab bentfab is offline
Doing it home with .028 wall it will most likely collapse on you in the middle of a bend. I sell and use .035 wall seamless tube.
Give me a buzz at the shop tomorrow and I can help you out with any questions or help guide you in the rite direction
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
