Old 02-09-2014, 07:45 AM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default TREMEC T56 for "mock-up"
Item Location (City/State): Mesa,AZ
Price:150.00
Description: VIPER Tremec T56 case. All internals have been removed (case is cracked and is ONLY good for mock-up) This would be very useful during fabrication ,etc. - $150.00 + shipping
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 02-09-2014, 12:00 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
That's a Viper T56, which places the shifter significantly more toward the front than an LS1 transmission, and places the cross-member mount about 1" to 1.5" farther from the centerline of the output shaft than does an LS1 or Magnum T56.
Old 02-09-2014, 06:15 PM
Default Viper Application
Mike, thanks for clarifying the application. I purchased years ago as advertised, and have had in storage. This appears to be a bit of a black sheep with what you have pointed out. None the less, Thanks.
Jay
Old 02-10-2014, 09:41 AM
Mkelcy's Avatar
Jay
No problem. I didn't want you to have an unhappy buyer.
Old 02-10-2014, 03:43 PM
silvermonte silvermonte is offline
Can the magnum t56 be ordered with the shifter in the same location as the viper t56? Im in the works of doing some engine set back and this would be handy to actually see where the shifter ends up.Would be handy for at least that, a cross member is fairly easy to fab.
