Old 02-18-2014, 07:24 AM
Sieg's Avatar
Sieg Sieg is offline
Lee Mfg is a good place to start IMO.
http://lee-powersteering.com/pumps.htm
Old 02-18-2014, 09:30 AM
David Pozzi's Avatar
You could just change the seal, heat probably damaged it. A cooler is a great addition. I wouldn't add a remote tank to your stock pump. The reservoir is removed, then the pump has to be drilled & threaded in a thin area of the casting, so the fitting could have leak issues. There have been plenty done this way, but it's just not ideal.
You could go to a late model pump, but they are no better. Sweet makes late model pump kits.
David
http://www.PozziRacing.com
Old 02-18-2014, 09:45 AM
SSLance's Avatar
SSLance SSLance is offline
Interesting David, thanks...
I'll go looking for a youtube on swapping out just the seal. The pump itself only has about 5,000 miles on it.
Lance
Old 02-18-2014, 10:20 AM
SSLance's Avatar
So you just replace the two O-rings inside the pump housing, the O-Ring that seals the reservoir to the pump, and the 3 O-rings for the hose and bolt locations? That's it?
How come I've always just replaced pumps instead of fixing them in the past?
Lance
Old 02-18-2014, 11:55 AM
SSLance's Avatar
Or is it just the shaft seal that is leaking and if so can it be changed without pulling the pump apart?
Lance
Old 02-18-2014, 12:58 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Lance... I've had problems in the past with power steering pump leaks in my Camaro. The leaking problems started after I began tracking the car. The fluid would over heat and boil on occasion. Over time the excess heat ruined the seals (like David said). I rebuilt my pump with the rebuild kit and it solved the problem. You do have to take the pump apart to replace the shaft seal.
Also-- use a synthetic blend power steering fluid with a higher temperature service capability. I'm running Royal Purple in mine.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 02-18-2014, 02:43 PM
SSLance's Avatar
I think I'll attempt that this weekend. It looks like I can pick the rebuild kits up locally pretty cheap and doesn't appear that hard to take them apart and reassemble.
I know I have boiled the fluid out of this one several times so I'm sure that's what did the seal in.
Lance
