Old 03-28-2006, 11:12 PM
fennerford fennerford is offline
my 79 camaro isnt much now because i'm in highschool and have a limited budget but it's actually been coming along pretty well. i already got some 11 inch tires on the back because thats all i could fit without looking stupid. the exhaust is work in progress and its mostly body work now but what do u expect from a 400 dollar car that didn't run in a year. i got everything running in 2 days. i'll try to get her outside tomorrow if its sunny so i can take some nicer pics.
do u think i should submit it?
79 Camaro Berlinetta
"Linett"
http://www.cardomain.com/ride/2282853
Old 03-29-2006, 07:04 AM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
Once I set the body on the new chassis, (should happen this week) I'll get some good pics and submit mine... at least when that occurs, I can consider it a Pro-Touring car, despite the 15" wheels.
Old 05-09-2006, 02:06 AM
groovyjay's Avatar
groovyjay groovyjay is offline
I just submitted my car... Hope to see it listed among the other amazing rides!
Old 05-30-2006, 07:50 PM
crazy1969 crazy1969 is offline
Default my 1968 camaro
here is my old 68 that i sold now working on my 69 camaro
Old 07-20-2006, 01:04 PM
spicer spicer is offline
I just submitted my 65 mustang. Hope to here back from ya.
Old 07-20-2006, 08:17 PM
nvawgn's Avatar
nvawgn nvawgn is offline
i would submit my car but i ran outa money again
Old 12-31-2006, 04:34 PM
JETSET700's Avatar
JETSET700 JETSET700 is offline
Default Peter Stewart's 67' Camaro
This is my 67' Camaro that I'm working on.
Up front it has DSE arms, ATS/AFX spindles, Big discs.
An LS-7 is coming to power it, with ATS stainless headers.
UMI Delphi 4B controller & harness.
Worked T-56, Twin disc, & ATS install kit.
Ricks stealth tank, RD radiator.
Old 01-19-2007, 03:34 PM
alfonsothefons's Avatar
alfonsothefons alfonsothefons is offline
Default 78 montebu
hi new to your site this is my lateral machine: 1978 malibu classic with major body mods ,fiberglass montecarlo front clip ,shaved doorhandles,rollpan
,wheelbase streched,backhalf 4 link system wtith koni coilover shocks and wishbone track locator,custom rear swaybar,dodge 8.75 rear with 4.88 gears,
454 .30over,rect. heads,force efi cutler hyperflow,1000 cfm throttle body 43 lbs/hr inj., Haltech f9 fuel managemt,MSD complete billet system ,630 lift roller cam,
electric waterpump,oberg oil system, Standard elec. oil preluber,russell braided lines,supercomp headers,
hotchkiss tubelar a arms ,addco sway bar ,cadillac 12in calipers and rotors, 11 in dodge truck drum brakes
Rockland Gears viper t56 6 speed,mcleod clutch,alum radiator, alum driveshaft,alum interior ,alum engine compartment,15 gl. harwood fuel cell,6 point rollbar
lexan windshield and windows and factory air,
have new motor in works ,Magnesium block 511 bbc with titanium innards for salt flats
Old 03-10-2007, 08:22 AM
prostreetamx prostreetamx is offline
My 72 Hemi Javelin is progressing fine and I plan to try to finish it up this summer. I started with a 72 Javelin shell and added lots of stuff from a 2004 Hemi truck, including the drivetrain and dash as well as most of the power options. The car rides on Shockwaves in the front with a mostly stock for now front suspension. I have a Mustang rack hooked to the Hemi pump and steered by the truck wheel. I had to section the dash about 12" for it to fit. In the rear the car rides on an Air Ride angled 4 link and Shockwaves. It has an 8.8 disc brake rear out of an Explorer with 3:73 limited slip gears. The back has been minitubbed for 17x11" wheels. I added homemade subframe connectors to stiffen up the chassis. I did not put a cage in this car since I already have a Prostreet 77 AMX. Pictures can be found on Photobucket.com under Hemi Javelin.
Old 04-17-2007, 11:02 PM
novanutcase's Avatar
novanutcase novanutcase is offline
Do you want progress pics or are you only interested in finished cars? If it's progress pics i've clogged your server with plenty!
https://lateral-g.net/forums/showthread.php4?t=4432
Use whatever you need!
John
