Old 02-27-2014, 10:20 PM
smhigh's Avatar
smhigh smhigh is offline
Default push button starting system
Most systems I'm familiar with have you step on the brake and push the button to start.
If you just push the start button without pressing on the brake pedal it turns on accessories.
Here is a description of an add on system....
Functions
This kit has 4 functions for the push button start feature.
Once inside vehicle
***Without holding the brake***
1. Press the button once for ACC (radio)
2. Press button a second time to turn the car into the "ON" start (All electronics on)
3. If you press the button a third time this will shut the entire system off (all electronics off)
*anytime during this process you can press & hold the brake & push the Engine start button to start the engine. You do not have to turn the system into the off state to start the engine
***With brake pressed***
1. Press the engine start/stop button to start the vehicle not to exceed 1 second
4. Hold the brake & press the button for 1.5 seconds to turn the vehicle off so it will not shut the engine off if button is accidentally pressed.
