Old 03-05-2014, 09:17 PM
MX145 MX145 is offline
We got the 86 Blazer tilt column mocked up. The NRG hub and Quick Release are very tight and look to be well made.
The column has the key location so my dad cut it off with the sawzall and turned it down in the lathe to prep it for boring a 1-1/8 hole to plug it.
The press fit plug worked great! You can't even see it after he final turned it on the lathe.
The black half moon low area is in the casting outside of the plug. It's only a couple thousandths deep so it will disappear when prepped for paint.
I'm waiting on rag joint rebuild parts so we can finish up the column. The "new" ebay Borgeson rag joint I bought has mismatched pins and locknuts. It's obviously been apart before.
[IMG]http://i1158.photobucket.com/albums/p603/mx267/Transition%20Camaro/6245CAAF-B050-4123-9191-C3EEDF4DBBD4.jpg[
Old 03-05-2014, 09:32 PM
I welded up the floor x-member seam from the top and bottom along with the subframe connectors and rear x-member seam to get ready for epoxy.
I finished trimming the front x-member and modified the factory transmission x-member and floor so I can still remove it with the 1/2 height DSE body mounts.
A lot of elbow grease under way prepping for paint.
The underside is now in epoxy from the frame rails in. I have more work to do when it's off the platform style lift as the outside areas aren't accessible.
Old 03-05-2014, 09:46 PM
I put the rear end back in the car for final fit up.
Parking brakes and axles went in.
I put the rotors and calipers on to set up the shims.
Old 03-05-2014, 11:35 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Awesome work, Ryan! It's funny- the second I read "86 column" I was thinking about the ignition key area, and all I had to do was look at the second pic posted and see that it was all taken care of.
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 03-06-2014, 12:41 AM
getting very close!!!
Old 03-07-2014, 01:33 PM
Nice work, it looks good under there. Nice job on the column too.
Old 03-07-2014, 06:01 PM
WSSix WSSix is online now
Nice work! What color are you planning for under the car, black?
Old 03-07-2014, 07:04 PM
Thanks guys! My dad deserves a lot of credit for the progress. We divided up the work to try get something done. It seemed like we weren't getting anywhere for a while there.
He made most of the machined parts. The column is turning out nice. He made this transition piece to go from the lower cover to the 4" upper section. It's got a step in it to slip over the lower cover and hold it tight.
Old 03-07-2014, 07:06 PM
Thanks Trey! Yes black.
Old 03-07-2014, 11:39 PM
Wow man that is looking great. You and pops are kickin some butt.
