Old 03-16-2014, 06:17 AM
kwhizz's Avatar
kwhizz kwhizz is online now
I finished the exhaust system and got another Education on Welding.......I finally got the wire feed and voltage dialed in on the last weld........Typical..........But.....In building the other LS powered cars I always seemed to have issues with the "Rappy" sound out the exhaust pipes and ended up changing mufflers a couple times to get away from it..........I think the length of the tail pipes have something to do with it........But.......On this car I bought Dynomax #17749 super turbo mufflers and brought the tail pipes out behind the rear tires........so ....when I started it I didn't know what to expect.........I wanted the quietist performance Muffler I could find...........so.....When I started it........I was very pleasantly surprised at how you could hear the exhaust.....but yet how quiet it was........Perfect!!!........Going down to Stefano at Nickey next week to get the rough edges blended together in the ECM............When I started the build I had the complete ZL1 harness assy........But......because I decided not to use the 6L90E trans we couldn't use the ZL1 harness ........John at Speartech supplied a ECM set up to work with the engine and the 4L70E trans......but....It needed to dialed in to blend everything together......so......Stefano and Cory are going to put the final piece of the puzzle in place.............Then it's going to Frame-Up to get the A/C system charged......83 days till Power Tour.......
