Old 07-23-2006, 06:24 PM
awr68's Avatar
awr68 awr68 is offline
Default quick 4-bar ??
My AME 4-bar brackets are setup with 6" between the mounting points, would it hurt or kill performance if I lessened the space between them to 5" with the bars parellel? I lowered my car quite a bit and need to get the bars level again and packaging reasons don't allow to keep the bars 6" apart anymore. Thanks in advance!!
Tony
'68 Camaro
Old 07-24-2006, 01:52 PM
Musclerodz's Avatar
Narrowing the distance will increase torsional load on the bracketry. Just make sure the bracketry is beefy enough to take the extra load.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-24-2006, 05:59 PM
Mean 69 Mean 69 is offline
Which brackets, LCA on the axle?
M
Old 07-24-2006, 10:04 PM
awr68's Avatar
Mark, I was thinking of relocating all mounting holes except the upper x-member holes. If I do this and close the gap between the bars to 5" from 6" I can get the bars level and clear the floor with room for bump at the desired ride height.
Tony
'68 Camaro
