Description: Not sure of exact model but came on my 68 Camaro with non-tilt stock column and have used 2 different Sparco wheels on it (330mm and 350mm)
I've been looking for one of those, do you know if it will fit a 67 column? what is the part number? I have a Grant 3hole wheel not sure if it will bolt to that one, but I'm interested how it bolted to the spline.
No Shop, No Money, No Time.... No problem!
I'm pretty sure that's the same one I have (the 2.5 model), and that it required an adapter to the GM column. There is a 1.5" thick adapter which bolts to the column using the stock splined shaft and nut, then you use the 6 bolt holes to attach the quick release.
