Old 07-30-2006, 11:20 PM
Dodgenut64 Dodgenut64 is offline
Default using stock tank for EFI?
i was reading about the Dust Ya duster in a popular hot rodding artical. to qoute the artical it said "To feed the FAST EFI unit, Strope mated a ’90 Corvette in-tank electric fuel pump to the stock Duster sending unit."
has anyone taken their factory tank and converted it into an in tank pump? im new to this fuel injection thing and any info about converting over my tank for fuel injection would be very helpful. ill be using a new 5.7 or 6.1 hemi with EFI .thanks
Old 07-31-2006, 03:04 PM
69 L88 Camaro 69 L88 Camaro is offline
Default EFI pump/Non EFI tank
The picture is perfect. EFI pump hanging on the sender mount with a return. Make sure you have a vent and that looks good. Size the pump per HP.
Old 07-31-2006, 03:39 PM
Also provide some sort of in-tank baffling or always keep the tank full. Without a baffle I could uncover the pickup easily with hard acceleration and even 1/2 tank of fuel or so.
Old 07-31-2006, 05:44 PM
67PTCAMARO 67PTCAMARO is offline
I got bottom pick-up without baffles and driving it less than1/4 of tank and did not have problem. Maybe I did not accelerate/turn hard enough. In the event it runs out of fuel does it hurt bad enough?
67LS1T56
Old 07-31-2006, 06:04 PM
With a carb if the pickup was uncovered briefly you still have the fuel in the bowls, so you'll likely not even notice. With EFI it's an immediate glitch which would cause a lean condition. I've had problems in a couple of cars without baffles, but these cars accelerated pretty hard.
Old 07-31-2006, 06:17 PM
What kind of damage that immidiate glitch would cause?
67LS1T56
Old 07-31-2006, 07:38 PM
ahowudoin ahowudoin is offline
One thing that comes to mind first is the only thing that keeps that pump cool is the fuel.Keep running it low and it won't last.
Old 07-31-2006, 08:44 PM
That would depend on the motor. On a forced induction/nitrous it could be deadly as leaning it out even temporarily is very bad. On a naturally aspirated engine it still isn't good and could cause damage.
Old 07-31-2006, 11:16 PM
the pic above was from the artical. so a float or baffle is a must then? what does the float do? im green, real green at all this stuff.
Old 08-01-2006, 12:30 AM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
I've experienced what jody is talking about! I have a stock Monte tank with a GN in tank fuel pump with no baffel's. When I go around corners with the tank low on fuel and get on the gas, it pops and hesitates alittle. And it pops on hard accelerations too, Something I definitly need to take care of!
BRIAN WEST
